AEM EMS Get tuning help for your AEM EMS system.
aem ugo gauge help
Old Jan 31, 2007 | 03:00 PM
teamdomokun's Avatar
Angry aem ugo gauge help
ok well I have just a little problem. its with my gauge. It will work for about a whole 5 sec going from lets say 13.0 to 15.9 bouncing around then it will just got off the chart above 16 and never come down. mods are in the sig i don't get it. and its kinda has a farting noise when im driving at a constant speed like a pop pop pop but thru the exhaust. and it smells real rich. any thing that will help me with this problem will help greatly. thanks again. I think that i just need a re tune but what do i know im not a guru like you guys here. ams has done all the installing of the aem ugo aem ems alky.
thanks again
Craig
Old Jan 31, 2007 | 03:02 PM
AutoMotoSports's Avatar
it sounds like something else is wrong with the car. If its going off the scale Rich. the car is most likely rich.
The first Thing I would look for is a nasty boost leak. That will cause you to run very rich and cause that pop you are experiencing.
Eric
Old Jan 31, 2007 | 03:07 PM
Eric
I have checked for a boost leak i have not seen anything and its like -20 on the gauge like it always has been at idle. how much would a retune be from you guys. you can pm me a price for the dyno. its been doign it for a week now but ill check again for a leak I hope thats all it is.
Thanks again ams
Craig
anybody else plz put your 2cents in
Old Jan 31, 2007 | 03:28 PM
Fourdoor's Avatar
thanks again
Craig
Off the chart high is ultra lean... is your alcohol pump working properly?
Keith
Old Jan 31, 2007 | 03:36 PM
I haven't used it in awhile. I couldn't remember if it was alky or meth so i turned the boost down to 20psi and have just been driving it normal till i could get it re-tuned and found out for sure what it was alky or meth. ams said that if they installed it and tuned it which they did its meth. but i don't wanna take the chance of it going kaboom so im taking it easy and wanting to get a retune. but now this happens so idk i have not been having any luck the last 4 months so this just adds to the cake.
Craig
Old Feb 3, 2007 | 01:25 PM
update. now its stuck at 14.7 and does not move
Old Feb 3, 2007 | 05:22 PM
The Devils Z's Avatar
what did you do differently ? If it's stuck at 14.7 you might want to check the connector to the sensor. It will read 14.7 if the sensor harness is not plugged in
