AEM EMS Get tuning help for your AEM EMS system.
installing EMS
Old Mar 22, 2007 | 07:26 PM
dustin03's Avatar
installing EMS
I have a few questions about the ems before I go an install it in my car if you have one on your car and willing to answer my questions pm me and I will give you my number.
Thanks,
Dustin
Old Mar 23, 2007 | 05:02 PM
AMSTuning.com's Avatar
Brocef, just post them here, or search. What are they?!
Old Mar 24, 2007 | 03:40 PM
dustin03's Avatar
I will be doing the ait sensor does that mean I will not have to run a maf anymore? Also where can I find the wire diagram to hook uo my map sensor and ait sensor?
Old Mar 24, 2007 | 04:31 PM
You are either keeping the MAF or doing a full speed density conversion and getting rid of the maf. You need to have some sort of an idea as to which direction you are going, as they are 2 different things. Speed density is usually the way to go.
INTAKE TEMP SENSOR
IAT Sensor is to be tapped (tig welded) into upper intercooler pipe closer to throttle body, you want to measure the temperature of the air coming into the engine.
INTAKE TEMP SENSOR IS WIRED ACCORDINGLY:
OEM MAF PLUG, FIND 2 WIRES BLACK AND BLUE/RED
!POLARITY DOES NOT MATTER!, Wire 2 wires off IAT to OEM MAF plug wires above.
MAP SENSOR
MAP Sensor is to be tapped into the intake manifold. Looking at the fuel pressure regulator assembly; look to the right of it (towards driver side) and locate the MDP sensor. These sensors are near each other. Remove the plug from the MDP sensor and unbolt the actual sensor unit removing the unit entirely. You can use an adapter in place of the factory MDP sensor allowing the MAP sensor to replace the MDP. If you do not have the adapter; you can leave the MDP sensor in its place and find a good neg/pos vacuum source right of the intake manifold.
USE THE WIRES ON THE MDP PLUG AND WIRE THE MAP SENSOR ACCORDINGLY:
MDP - AEM MAP SENSOR goes: black to black, red to grey, and yellow to green
Old Mar 24, 2007 | 09:06 PM
dustin03's Avatar
what would I need to do to convert to full speed density? I have a bung for the ait sensor. Since I have the ait sensor is there anything else I need to get?
Old Mar 25, 2007 | 12:13 AM
Exclamation
You need a MAP sensor, 3.5bar, or 5 bar, AEM makes them, or you can get a GM sensor.
Old Mar 25, 2007 | 10:47 AM
dustin03's Avatar
Sorry for all the questions but once I put the iat and map on the car I can take the maf out? If this is so do I just leave the wire harns laying in the car for it?
Old Mar 25, 2007 | 12:19 PM
Exclamation
Once the MAP sensor is wired into the stock MDP plug; and IAT is wired off the 2 MAF plug wires, the maf is no longer needed and can be removed, leave the plug.
With that said, your base calibration is going to be MAP obviously, 3.5bar.
Old Mar 26, 2007 | 06:48 PM
dustin03's Avatar
thanks for all the help
Old Apr 15, 2007 | 06:29 AM
SuperStreet2K6's Avatar
Is there any advantage to the 5-bar over the 3.5-bar or does it just depend on how much you plan on boosting?
Old Apr 15, 2007 | 07:26 AM
Exactly. Usually there's about a 33 psi map limit on the 3.5 bar.
