AEM EMS Get tuning help for your AEM EMS system.
Air fuel ratio?
Old Aug 27, 2007 | 07:11 AM
milo's Avatar
Air fuel ratio?
On my Evo, when I push the gas pedal at WOT, the a/f ratio stays at 13 to 1 for a few sec til I hit 22psi, then it goes to 11.5 to 1. Is this normal and safe or should I tune it to a little more on the rich side?
Also, it feel really lagging when I press the gas pedal........till I get a full boost.
Old Aug 27, 2007 | 08:14 PM
alpha's Avatar
It shouldn't be at 13:1 until 22lbs
Old Aug 27, 2007 | 08:58 PM
milo's Avatar
Kewl, thanks.
Old Aug 28, 2007 | 09:51 PM
MZP@TeamD's Avatar
Former Vendor
Air fuel ratio?
Can you post one of your logs, so we can take alook at it?
Old Aug 28, 2007 | 10:31 PM
quick silver 8's Avatar
kinda lean there , be careful because that doesnt sound too safe
Old Aug 29, 2007 | 06:18 AM
GTVEVO's Avatar
Remeber as boost builds AFR should lower like a weight scale, this is also very hard to do with the stock turbo so be sure you have your calcs straight. Making sure you have a very smooth transition will help throttle responce and safe power.
Old Aug 29, 2007 | 12:43 PM
milo's Avatar
Is 11.5 A/F ratio good at wot with 22psi of boost on 93 pump?
Old Aug 29, 2007 | 02:26 PM
Spaceball 1's Avatar
Yes Just fine
Old Aug 29, 2007 | 02:49 PM
Ph3n1x's Avatar
11.5 in 4th gear is great for safety and power
11.7 spool up, 11.5 peakboost, 11.5 throughtout the band, 11.2 towards the top.
cts4g63
Jan 6, 2016 02:22 PM
EvoOtto
Oct 5, 2015 12:42 AM
hevek
Oct 25, 2012 09:32 AM
C_LosEvo
10
Oct 28, 2011 08:57 AM
