AEM EMS Get tuning help for your AEM EMS system.
Boost Controller Creating a Boost Leak?
Old Dec 10, 2007 | 02:27 PM
tabio42's Avatar
Using a 3 port boost controller such as the AEM solenoid - When you are at WOT, isn't the boost controller essentially creating a boost leak by diverting pressurized air out of the 3rd port on the solenoid?
Does this cause any tuning issues? Make you lose power? Anything?
Old Dec 10, 2007 | 03:14 PM
Jason@PSI's Avatar
Are you running the stock MAF or are you now on speed density?
Old Dec 10, 2007 | 03:15 PM
awdboosted's Avatar
It will be so small it will not even mater.
Old Dec 10, 2007 | 03:37 PM
tabio42's Avatar
even at near 100% duty for the solenoid?
Old Dec 10, 2007 | 10:38 PM
awdboosted's Avatar
At 100%??? That will depend on how the lines are run.. But I don't think 100% is achievable. Last time I check it was 10-90% duty.. But if you care so much about it run a line from where the filter is suppose to be, and install it before the turbo and after the MAF or filter if you don't have MAF. Problem solved.
Old Dec 10, 2007 | 11:01 PM
fostytou's Avatar
EvoM Community Team
I was wondering about this the other day. The same thing happens with all of the MBCs that have a "Boost recovery hole" and with the greddy solenoid that I have on my 2g.
The only "issue" i was thinking could pop up would be that there is probably slight vacuum in the area you would plumb it to (the stock inlet hose location) which could make it even harder for the TruBoost or any other controller to do its job properly as you would be sucking the air in the line out rather than just removing pressure from it temporarily. I'm under the impression that it is no big deal... with the Greddy and the TruBoost you won't leak any at idle or up till your spring crack point.
If you do decide to re-plumb it please post results and weather or not your boost controller can keep up... right now at 59% duty I see enough dropoff on the TruBoost, but I'm interested to find out!
Old Dec 11, 2007 | 09:01 AM
tabio42's Avatar
Re-plumbing is not going to help me unfortunately since I am not running a MAF. With my setup, lost air is lost air regardless of where it comes back through. But I suppose that as long as I am not losing pounds of air mass through the hole it should be ok... ?
Old Dec 11, 2007 | 10:27 AM
2JZfan's Avatar
Tabio,
I think you are confused as to how this is supposed to work... the vent port vents the pressure that was trapped in the wastegate, not the pressure coming out of the turbo. At 100%, the turbo is blowing against a completely blocked solenoid and the wastegate chamber is able to fully vent to atmosphere. At 0% the boost is blowing directly into the wastegate. So in either case, there is never a situation where the turbo is hooked to the vent causing the larger leak that you are concerned about...
Old Dec 20, 2007 | 10:45 AM
tabio42's Avatar
Originally Posted by 2JZfan
Tabio,
You sir are 100% correct. I was totally thinking backwards. Thank you!
RS200
Jan 23, 2016 04:19 PM
maperformance
21
Oct 27, 2009 03:14 PM
Koroshiya
108
Oct 26, 2009 02:39 AM
KevinD
Jul 16, 2009 11:28 AM
