AEM EMS Get tuning help for your AEM EMS system.
ecu off line?
Old Apr 20, 2008 | 06:36 PM
mitsubishifreak's Avatar
ecu off line?
hey i am trying to connect to the ecu with this new laptop.it is a serial to usb adapter and i have the correct port.it will start to connect the just freeze and wait...it says
"Loading serial communications library"
"Initialising comms..."
"Serial comms initialised"
(Box pops up saying Querying ECU, then it says)
"Offline"
Then at the bottom there's a red bar that says "ECU OFF LINE"
it just waits there ..... i have tried to connect with key off then acc on, key off to power on, etc.... old laptop crapped out and need this one to work. any help thanks guys.
Old Apr 21, 2008 | 06:47 PM
GTVEVO's Avatar
"Offline"
Sounds like inconpatible adapter, might try to set the port to a slower speed. This may or may not work but its worth a shot. Why type of adapter is it so others can take note and maybe chime in with more troubleshooting.
Old Apr 21, 2008 | 08:58 PM
bought adapter from best buy does not have any name stamped on it anywhere and cannot find box.i also am not sure it came with a driver disk ether? how do i change the port speed? i read also something about port3 being for modems useally?
Old Apr 22, 2008 | 02:48 PM
jutilat's Avatar
Usually, they come with drivers on a CD. It sounds like the serial to USB adaptor you bought may be junk. I read around before I bought mine and people have mixed answers on which ones work and which ones don't. I heard good things about the ones from radioshack. Try to get one with drivers that is compatible with your os, keep the receipt and return it if it doesn't work. Also, if you can get any information about the one you have. Look up the company and find the drivers online, a good company offers them there. USB to serial can be finicky. Good luck.
Old Apr 24, 2008 | 11:47 PM
finallyevo's Avatar
I have always had problems with USB to serial adapters. I must have tried 3 or 4 different brands and they never connected me to the ECU. I ended up going on ebay and buying an old school sony vaio for $150 that had a serial port. Never had any problems since then.
Old Apr 25, 2008 | 08:13 AM
GTVEVO's Avatar
I believe I use an IOMajic or IOGear can't remember adapter that I purchased from BestBuy. No issues at any time. I believe there is a list on aempower fourms on compatibility and some having issues.
Old Apr 25, 2008 | 09:15 PM
hahah i win
i bought the new serial to usb adapter called gigaware.it is made by radio shack.i installed the drivers and hooked up with key on engine off.i had to change the port on the ams software to the port listed as the gigaware and hit connect. it went right away and has worked flawlessly.highly reccomended.thanks for the help guys.
real fast
AEM EMS
14
Nov 15, 2017 09:06 AM
darkeye
Oct 2, 2015 09:47 AM
Jspec EVO VIII
Jan 19, 2008 11:38 AM
bigric09
Nov 9, 2006 12:02 PM
MalibuJack
113
Mar 25, 2006 04:10 PM
