AEM EMS Get tuning help for your AEM EMS system.
Can you use a switch to change maps on EMS?
Old Jun 10, 2008 | 11:15 AM
shunderwunder's Avatar
I got an AEM EMS & will be installing it after I get a few more things. I know you can have multiple maps & change them with your computer, but can you install a swith to change the maps without the computer. I have seen this done but I am unsure if it was with AEM EMS or some other EMS system. If it can be done then what will I need to do to set it up? What kind of switch? what pin/pins do I connect the switch to? What do I need to do as far as programing goes to alow this to work? Thanks for any help you guys can give me. I searched, but couldn't find anything on the subject directly related to the AEM EMS.
Old Jun 10, 2008 | 12:24 PM
tseitz123's Avatar
Yes, use switch#7, refer to manual for what pin that is, and use anything you want as a switch (i.e. I/C sprayer button, wire a separate switch, the switch on a meth kit, etc. The separate maps (fuel and ignition) will be the Nitrous maps. Switch#7 will be what activates or deactivates it.
Old Jun 10, 2008 | 01:10 PM
Thanks a ton. So do I just ground the other wire from the switch?
Old Jun 10, 2008 | 01:12 PM
tseitz123's Avatar
pretty much.
Old Jun 13, 2008 | 04:57 PM
boostmaster's Avatar
this will only adjust ign and fuel maps alone when the switch is activated, the water, air comp. etc. will remain the same.
Old Jun 13, 2008 | 06:41 PM
I'm not too familliar with what all is included in a tune, so would there be a need for it to chacnge other paramiters than ign & fuel maps? what I'm looking to do is to have a normal tune & a meth tune. I know I'd have to have a separate switch to turn the meth on & off.
Old Jun 14, 2008 | 07:17 AM
tseitz123's Avatar
https://www.evolutionm.net/forums/sh...ighlight=hfs-5
Read
Old Jun 14, 2008 | 07:55 AM
Very helpful thanks. Now comes the hard part. Extra money.
Old Jun 27, 2008 | 07:52 PM
Mulholland0132's Avatar
Good read.
monsterevo7
AEM EMS
Sep 9, 2016 04:55 AM
GravityKnight
AEM EMS
Apr 2, 2015 10:30 AM
06ravenmr
AEM EMS
Oct 29, 2009 01:57 PM
nutrulz
AEM EMS
Aug 18, 2008 01:49 AM
0100
AEM EMS
Jun 10, 2007 08:15 PM
