AEM EMS Get tuning help for your AEM EMS system.
Installing external switch for different maps for different fuel.H E L P!
Old Aug 26, 2008 | 10:20 PM
evovin's Avatar
Question Installing external switch for different maps for different fuel.H E L P!
I can't find here the answer.... on how to Install external switch to AEM EMS for different maps for different fuel???
Old Aug 27, 2008 | 11:06 AM
jessvolution mr's Avatar
if i'm not wrong, only motecm800 or so can do map switching..
not too sure whether aem can do it..
Old Aug 27, 2008 | 12:46 PM
evovin's Avatar
I saw it somewhere here last year but I couldn't find it
Old Aug 27, 2008 | 02:43 PM
awdboosted's Avatar
There is no swich for AEM. You may be able to play with the NOS maps and have them add or subtract fuel/timing. It's just easy to swich maps using a laptop.
Old Aug 28, 2008 | 09:40 AM
chuckbyu's Avatar
Like Mike said you have to use the NOS map. Tune your base map to one setting then you have to wire a switch to activate the NOS map and tune that for your second setting. The switch then changes between base map and NOS map. Good luck.
Old Sep 9, 2008 | 10:45 PM
omniprobe's Avatar
To be on the safe side it's always better to use a laptop and confirm the map swtich. An external swtich can have malfunctions, goodluck .
Old Sep 9, 2008 | 10:53 PM
AWD Motorsports's Avatar
Old Sep 26, 2008 | 08:44 AM
awdboosted's Avatar
You could always set up an LED to light up when using the switch. It's just an idea.
Old Oct 7, 2008 | 05:08 PM
sniper3818's Avatar
is possible to install a switch for low and high boost, when its switch to high boost map the check engine light turn on to confirm the switch over. i just wish i knew how to install it.
Old Oct 7, 2008 | 06:29 PM
Fried_rice's Avatar
^ You don't need to switch maps... Use a boost controller... You can use the same map for 93/c16 if you need to. Is it really that much of a problem to switch the map with a laptop?
Old Oct 29, 2008 | 01:55 PM
blacksaleen95's Avatar
There really is no need for switching maps since you're at different load cells for higher boost so your timing and fueling will already be setup. If you have a high/low boost switch setup you're essientally having 2 maps cause you really could have the high boost setting tuned for c16 or something if you wanted.
There's prob a way to do it with ign/fuel dif map, similar to how some of you guys are setting up the meth.
I know of some guys using the flex fuel sensor (0-5v) as a fuel trim for gas/e85 setups. You could configure some alt settings to work with that as well.
