AEM EMS Get tuning help for your AEM EMS system.
Coil Dwell, I don't think its right causing weak spark.
Old Apr 15, 2009 | 09:27 PM
  #106
EVO8_PR's Avatar
settings working excellent 39 psi tapering to 36 and no hiccup
Old Apr 17, 2009 | 06:10 AM
  #107
El Boricua's Avatar
CONGRATS man...!!
can't wait to see those maps..!!
Old May 27, 2009 | 10:39 PM
  #108
mtevoracer's Avatar
Great thread! I have had issues since I installed the AEM EMS. I made 487WHP on AMS dyno with the stock ECU, and I ran .24 gap then. No issues besides the occasional misfie code. The car is an 03'. I then had an EMS installed, instantly noticed alot of misfiring at part thottle, and at high boost. And it didn't preform the same untill full boost. Still does it today.
I'm heading to get tuned in the middle of June and I have to drive 14-16 hours to get to a reputable shop. And when I'm there I don't have anytime to order parts and all that and I've been thinking of what He told me the last time he tuned the car, "You need another ignition system. You don't have any left." And I just looked at the map and it's still set on the base settings.
Thank god you guys figured this out. Very intuitive. This is why I think Evom users are the most involved and knowledgable import owners on the web. Thanks.
I'll post up logs as soon as I have them.
Thanks!
Old May 27, 2009 | 10:41 PM
  #109
mtevoracer's Avatar
Do you mind if I put this thread in my Signature? I think this is a very informitive thread that cen help the community.
Old May 28, 2009 | 05:38 AM
  #110
GTVEVO's Avatar
Not at all, let us know your improvements.
Old May 28, 2009 | 11:59 AM
  #111
mtevoracer's Avatar
I'll get it posted as soon as I have hard data.
Old May 31, 2009 | 12:54 PM
  #112
EVO8_PR's Avatar
Just curios to know what spark plugs, gap, and boost levels have people with AEM and no ingition amplifier run?
PLUGS: NGK BR8EIX
GAP: 0.021"
BOOST: 39psi
HP: 630hp
MAX RPM'S: of 9500 rpm's
Old May 31, 2009 | 04:38 PM
  #113
whoflungpoo's Avatar
PLUGS: NGK BR8EIX
GAP: 0.021"
BOOST: 39psi
HP: 630hp
holy crap.
what kind of gas are you running?
plugs: NGK BR7ES I think, I'll have to find my extra set to verify.
gap: 0.022"
Boost: 22psi
HP: ??? haven't dynoed yet trapped 114 in the quarter friday
Max RPM: 8200
Old Jun 9, 2009 | 12:11 AM
  #114
rh9's Avatar
rh9
I have been experiencing misfiring at only 1 bar !
I'm running a power fc d-jetro but the dwell setting seem to be completely different than the aem, has anyone got any experience with power fc's dwell setting ? It might work here too
if I gap them down to 0.022-0.019 the plugs only last 2 days and it starts misfiring badly
Attached Thumbnails Coil Dwell, I don't think its right causing weak spark.-fc.jpg
Old Sep 30, 2009 | 05:41 AM
  #115
GTVEVO's Avatar
I have had lots of questions about these settings here lately so I wanted to bump this thread to get it to show up on the list. I am still running strong on these settings with no issues.
Old Sep 30, 2009 | 12:01 PM
  #116
Thanks for bumping the thread GTV, Imho it probably needs to be a sticky here in the AEM section.
I had mine set to 105 flat across and had little issue with it. I took it to be tuned and at 3200 he ramped it from 105 down to 65 @ 5600 and kept it flat to redline.
Now, I was running the wrong heat range plugs (stupid me forgot that NGK went UP for colder heat ranges and bought BPR7ES's) but at 26psi he told me the ignition was acting funky and that was about all it had in it. I put down 460 hp and 328 tq.
now, I've put int some BR8ES's gapped at .023 and turned the wick up to ~ 29psi. It's better with the colder plugs, but I think I'm going to pull the dwell settings back up to 105 all the way across with a 1.25 max tooth. Just figured I'd seek input before I did.
I take it your coils are still holding up just fine GTVEVO?
Old Sep 30, 2009 | 12:10 PM
  #117
GTVEVO's Avatar
My coils are doing well, no issues at all. I would be guessing my car makes about 550 averagely to the wheels +/- depending on how much boost I run on my daily driving setting with 91 and meth/alky injection. Its tuned very safely and has been fine as far as the ignition coils go. Also I still run the stock heat range of plugs with or without alky/meth injection at no less than 24 psi. I don't see any reason to go up to a colder plug as any time I have tested a colder plug I made a few hp less and had less response. I think the stock heat range is 7.
Old Oct 1, 2009 | 01:35 PM
  #118
Okie dokie.
so I tried the new settings of 105 across and 1.25 max and this was the result:
Same stretch of road. In the first run it was on the initial settings The IAT's were about 5 degrees cooler on the second run, but showed negligible effect when I tried it with the temp correction applied.
but yeah, it definitely felt smoother. I'd say it works quite well. I'm hopeful I won't have to go COP to be able to hit 39psi on E85.
Old Oct 1, 2009 | 01:37 PM
  #119
GTVEVO's Avatar
Okie dokie.
Thats some great results, thanks for sharing!!!!!
Old Oct 18, 2009 | 12:39 AM
  #120
Street gear's Avatar
Ok I read through almost 8 pages of threads and just want to know what is the fianl setting? I make around 700 WHP so is it possible to run a reliable setup at my level using stock evo 8 coils? If so what is the recommended EMS settings?
