AEM EMS Get tuning help for your AEM EMS system.
Coil Dwell, I don't think its right causing weak spark.
Old Oct 18, 2009 | 07:52 PM
  #121
Street gear's Avatar
Question
Originally Posted by Street gear
Ok I read through almost 8 pages of threads and just want to know what is the fianl setting? I make around 700 WHP so is it possible to run a reliable setup at my level using stock evo 8 coils? If so what is the recommended EMS settings?
Bump for answers what happened to everyone on this thread
Old Oct 18, 2009 | 08:20 PM
  #122
GTVEVO's Avatar
The settings I have recommend put the dwell cycles at around 62-63% max charge time, I have listed them down below.
Coil Options
Coil Dwell Factor = 35
Dwell Max = 1.25
Dwell Min = 0.10
Dwell vs Batt Volts Table
6 = 80.86
7 = 80.08
8 = 77.34
9 = 74.61
10 = 71.88
11 = 69.14
12 = 66.41
13 = 60.55
14 = 54.69
15 = 49.61
16 = 49.22
Dwell vs RPM
0 = 75
800 = 75
1600 = 75
2400 = 80
3200 = 85
4000 = 95
4800 = 105
5600 = 105
6400 = 105
7200 =105
8000 = 105
8800 = 105
9600 = 105
10400 = 105
11200 = 105
12000 = 105
12800 = 105
Old Oct 18, 2009 | 08:26 PM
  #123
Thanks a million bro has these settings been tested to 700 WHP? Also what gap are you running .022 or less?
Coil Options
Dwell Max = 1.25
Dwell Min = 0.10
6 = 80.86
7 = 80.08
8 = 77.34
9 = 74.61
10 = 71.88
11 = 69.14
12 = 66.41
13 = 60.55
14 = 54.69
15 = 49.61
16 = 49.22
Dwell vs RPM
0 = 75
800 = 75
1600 = 75
2400 = 80
3200 = 85
4000 = 95
4800 = 105
5600 = 105
6400 = 105
7200 =105
8000 = 105
8800 = 105
9600 = 105
10400 = 105
11200 = 105
12000 = 105
12800 = 105
Old Oct 18, 2009 | 08:38 PM
  #124
GTVEVO's Avatar
Personally I run a gap of .24 on my plugs, I believe 700 hp has been achieved on the stock coils with the AEM and setting of this sort. At 700hp +/- the stock coils will be tapped out though so keep that in mind. Regardless these settings are going to get you as close as possible with what you have.
Old Oct 19, 2009 | 06:28 AM
  #125
El Boricua's Avatar
One Q....
Does the Dwell Settings affect the cold start..? or the starting of the car at all..?
Thanks,
Old Oct 19, 2009 | 06:31 AM
  #126
GTVEVO's Avatar
Originally Posted by El Boricua
One Q....
Thanks,
No, the only thing it could possibly do is cause the car to start better but I honestly haven't noticed much if any differences.
Old Oct 19, 2009 | 06:34 AM
  #127
El Boricua's Avatar
Thanks....
I must check the condition of my spark plugs then... Also, I removed the HKS DLII to test these settings... that's might be why I'm feeling the car s little different..!!
Thanks again.
Old Oct 19, 2009 | 08:52 AM
  #128
Thanks....
Thanks again.
You made an interesting point I have an M&W 12 box do I use the same settings as posted.
Old Oct 19, 2009 | 09:02 AM
  #129
GTVEVO's Avatar
Keep in mind the HKS DLI is a quality enhancement box and not a standalone CDI box like the M&W 12. The HKS DLI usually helps the quality of spark, the changes we are making is causing more spark energy and charge to move into the DLI box (if used) so it will do the same task it always has still trying to improve the quality of energy and its consistency.
The CDI box or M&W 12 is actually making/storing and amplifying large energy quantities to send to the coils with just a signaled event, you would only run the CDI settings in the AEM wizard of you use a CDI box due to the square wave signal needed in most cases to achieve the best ignition results.
Old Oct 19, 2009 | 09:18 AM
  #130
Sorry I did not fully understand the part quoted. Are you saying just run the Aem wizard based on the CDI box I am using and use the default settings it gives you?
Old Oct 19, 2009 | 10:25 AM
  #131
GTVEVO's Avatar
I am saying if you use a CDI Box that my settings will not give you any gain because the CDI box discharges power upon its own strategy. It only reads a signal from the AEM to know when to discharge. If you do not use a CDI box my settings will greatly improve the charge on the stock coils.
The HKS DLI is not a CDI box so you can and should use the settings posted above.
Old Oct 19, 2009 | 11:02 AM
  #132
Thanks for clarifying that point bro
Old Oct 20, 2009 | 05:46 AM
  #133
El Boricua's Avatar
GREAT info... thanks,
Old Dec 14, 2011 | 06:16 PM
  #134
SloEvo12's Avatar
It's been a couple of years - but this info is great. Giving it a shot tonight
Old May 24, 2013 | 07:05 AM
  #135
Ralliartize It's Avatar
Necro'ng this thread. Curious, were these test executed on Tephra v7? My Dwell tables in v7 don't look anything like the data points listed above.
