AEM EMS Get tuning help for your AEM EMS system.
How to properly set up NLTS with EMS?
Old Sep 16, 2008 | 09:24 PM
epson1's Avatar
Can anyone tell me what exactly i have to do to set it up? I'm assuming it has to do with the clutch switch and a rev limiter but i'm blind after that. Searching didn't really give me any information either.
Old Sep 20, 2008 | 01:43 AM
evovin's Avatar
+1
Old Sep 21, 2008 | 07:45 PM
chuckbyu's Avatar
What is NLTS? I'm Unfamiliar with that acronym.
Old Sep 21, 2008 | 07:48 PM
EvolvedGTI's Avatar
I am not sure if it means exactly no lift to shift, but it is shifting without releasing the clutch at all!
Old Sep 22, 2008 | 01:25 PM
awdboosted's Avatar
Keeping your foot on the gas using the clutch to shift.. Keep the BOV from open up and loosing boost. But it switches to a second lower rev limiter via clutch switch. Don't use Anti-lag.. It just doesn't work right with the EMS and it kills the turbo.
I'm not sure about 8's but 9's are already wire in. You may have to wire in the clutch switch to make the 8's work.
Old Sep 22, 2008 | 04:47 PM
epson1's Avatar
Yeah i don't think the 8's have a wired clutch switch. Cause i use the VSS for my 2 step and not my clutch switch.
Old Sep 22, 2008 | 08:41 PM
awdboosted's Avatar
So then you need to use the clutch switch to use NLTS It's very simple to wire in. Pick a port that is a switch. (pin 7 is switch #4). Then run a wire to the switch. ones a ground the other one isn't. Wire into the one that is not a ground. So when you step on the clutch it should always go to the second rev limiter. It will ground when you step on the clutch.
Old Sep 22, 2008 | 08:50 PM
evovin's Avatar
I might try it. So do I need to set up something else in my map too or that's it?
Thanks!
Old Sep 23, 2008 | 10:30 AM
awdboosted's Avatar
Yes. You will need to set up the speed to 255 and select the input as switch #4. I don't know if it will be inverted or not. You should be able to view it when stepping on the clutch you will see the rev limiter change.
PL_MR
Oct 18, 2016 04:49 PM
GSXPimp
Apr 12, 2016 06:10 AM
Teal2nnr
AEM EMS
Jan 20, 2016 09:00 PM
THANGEVO
Sep 27, 2015 11:08 PM
krazydan19
34
Mar 9, 2015 03:27 PM
