AEM EMS Get tuning help for your AEM EMS system.
EMS connection problem
Old Jan 20, 2009 | 01:40 PM
oNeSiC 8's Avatar
When I go to connect it keeps saying "no file for ecu version".
I checked and made sure it was on the serial connection port and I highlighted my connector. It's the Keyspan USA-19HS. It says that the ECU is online but then then window pops up and says "no file for ecu version".
Old Jan 20, 2009 | 02:23 PM
oNeSiC 8's Avatar
bump
Old Jan 20, 2009 | 10:05 PM
oNeSiC 8's Avatar
anyone?
Old Jan 21, 2009 | 10:53 AM
project_skyline's Avatar
which AEM are you using? New or Used? Known Firmware version?
Old Jan 21, 2009 | 11:36 AM
chuckbyu's Avatar
This message means the firmware on the AEM is not the same version as the file you are trying to open. It has nothing to do with your connection. You are connected to the AEM but your software isn't updated. Go to the AEM website and get the newest firmware.
Old Jan 21, 2009 | 12:29 PM
SuperTwinz's Avatar
http://forum.aempower.com/forum/inde...c,17194.0.html
Old Jan 21, 2009 | 07:40 PM
oNeSiC 8's Avatar
Ok thanks guys I just downloaded the update and ran the file and downloaded that. Anything else I need to do or will it be good?
Old Jan 22, 2009 | 09:44 AM
chuckbyu's Avatar
You should be good. Just make sure that if you have 1.19 on the AEM that you are trying to open a map that is version 1.19 as well. If they are the same then you should be good to go.
Old Jan 27, 2009 | 12:44 PM
oNeSiC 8's Avatar
I tryed it today and still says it "No File For ecu version" I updated the softwear it says v1.19. Any other ideas?
Old Jan 28, 2009 | 08:01 AM
SuperTwinz's Avatar
Did you power cycle?
Old Jan 28, 2009 | 11:09 AM
oNeSiC 8's Avatar
Could u explain what power cycle is?
Old Jan 29, 2009 | 11:32 AM
oNeSiC 8's Avatar
bump
Old Jan 29, 2009 | 07:10 PM
oNeSiC 8's Avatar
bumpppp
Old Feb 26, 2009 | 07:43 PM
oNeSiC 8's Avatar
bumpp
Old Feb 27, 2009 | 08:45 AM
alpha's Avatar
Try connecting with the key OFF. When it says ecu offline turn the key to ON
If the above doesn't work disconnect the negative terminal on the battery for five seconds. Then try the above again
If the above doesn't work it is the serial to usb cable you're using
