AEM EMS Get tuning help for your AEM EMS system.
How to setup NLS
Old Dec 24, 2015 | 09:07 PM
  #31
norcalSRTrida's Avatar
I'm sorry to bump this, but I am trying to get this right on my AEM EMS. Differen't car, but trying to get similar function out of it..
Currently, I want/am using Drag-style Anti-lag for launching... Activated by a clutch switch 'Switch #4 = Gnd Off', and is in use for VSS below 8mph.
regular 2step rev limit is activated by the same switch, 'Switch #4 = Gnd Off' with 2step 'OK Below VSS 255mph', so basically 2step is activated as a fuel cut any time the clutch is pushed, above 8mph.
I would like to utilize Rally Anti-lag for WOT shifting, and utilize fuel cut instead of ignition cut every time I shift, to help keep the turbo spooled.
Is there a way to utilize the Rally Anti-lag in conjunction with the Drag Anti-lag? Do I just click 'anti-lag' control, and set it to 'Switch #4 = Gnd Off', and Disable 2-step below 255 VSS?
What if I set "ALT_OK_Below_VSS" to 255? It will work as described at launch and WOT shifting?
Next question is does the Rally Anti-lag retard timing based on what settings you use from the Drag Anti-Lag?
Would setting the 2-step to something like this, have same function as the rally Anti-lag:
2-step fuel cut: 10000
2-step ignition cut: 7500
2-step retard: 7300
Wizard: Level-10 Hard Cut
With the retard and ignition cut set to hit below my max rpm shift point (8500) for the 2-step settings, would the effect be similar to the anti-lag when shifting?
Excalibur
218
Apr 19, 2022 01:58 PM
TRASHY_GTS
May 10, 2017 02:13 PM
617APEXCT9A
Aug 1, 2016 01:42 PM
nikush
Apr 1, 2016 04:56 AM
MetalMoshpit
Mar 17, 2016 06:23 AM
