AEM EMS Get tuning help for your AEM EMS system.
External switch for internal logging
Old Jun 25, 2009 | 04:19 AM
althemean's Avatar
I searched for hours last night and couldnt find what I needed.
From what I understand in the EMS software, I must configure on output (such as switch 7) to activate the log feature and to assign it all the params.
My question is,
How do I physically wire it into the ecu? What pin/input is switch 7. I have a copy of the ecu pin layout. Just not which one needs to be tapped.
I want to log on demand and not use the set params in the internal log for activation.
Thanks for any help.
Old Jun 25, 2009 | 04:03 PM
gudmundur's Avatar
Hi
Switch # 7 doesnt seem to be available on Evo computers but you could use Switch # 5 which is for 1313 pin37
I havent done it but it shouldnt be so hard
regards
Gudmundur
Old Jun 25, 2009 | 06:59 PM
althemean's Avatar
thanks for the response. Ive been reading through the manuals and it is pretty vague.
Old Jun 26, 2009 | 02:19 AM
gudmundur's Avatar
That is true.
Only input I have used is the clutch switch input and for that I used Switch #4.
But in theory using switch #5 should be just the same and then configure it under logging setup.
I would think that you should chech "log switch2
regards
Gudmundur
Old Jun 27, 2009 | 07:48 AM
althemean's Avatar
so how does the wiring go.
Ecu pin 37---->switch-------GND?
Old Jun 30, 2009 | 08:07 PM
kjewer1's Avatar
I don't have the software in front of me, but you would typically pick an available switch, wire it to the switch and then ground as you said, and then set the switch parameter to "Switch [insert number you wired to] Ground = on" or whatever suits your implementation.
Old Jul 1, 2009 | 01:05 PM
awdboosted's Avatar
You can use any pin as long as it's on of the switches but to activate it you will need a gnd to trigger it. Not a power source.
kiddsm95
Feb 18, 2016 06:01 AM
Sp1kE
Jul 23, 2015 05:50 PM
RS200Z
Jan 12, 2013 06:42 PM
clockworktoy
Dec 11, 2011 12:20 AM
foxbat
Jan 26, 2011 11:58 PM
