AEM EMS Get tuning help for your AEM EMS system.
Help Starting
Old Oct 25, 2010 | 05:12 PM
benderrodriguez's Avatar
Help Starting
I've read lots of different post regarding starting issues, and I've tried all of the fixes with some improvements but the problem is still there. I have a 2.4 with 1000cc twin fuel pumps 93oct. Does anyone have a similar setup they would be willing to share a map or some things to look for, like approximate timing advance or fuel injector pulse width? Any help would be very very very very appreciated!
Old Oct 31, 2010 | 03:25 PM
Can anyone help?
Old Oct 31, 2010 | 04:41 PM
Tbtalon94's Avatar
Series 1 or Series 2 AEM?
Old Nov 1, 2010 | 04:37 AM
Series 1
Old Nov 1, 2010 | 05:22 AM
Tbtalon94's Avatar
send me over your map and i'll take a look. I'll PM you my e-mail.
What exactly is your starting issue?
Old Nov 1, 2010 | 08:31 PM
It cranks and takes about 3-5 seconds to start. It also dies early, and may require restart. Whatever I adjust seems to make it worse.
Old Nov 19, 2010 | 05:48 AM
Tbtalon94's Avatar
Did you ever try my settings? Or get it working right?
Old Nov 20, 2010 | 04:25 AM
I'm actually dying to. I found an issues with my MAP sensor (its an AEM 5 bar) and it only reads negative pressure up to atmosphere and then stops. I suspect it might be inaccurate at vacuum readings as well so I'm trying to fix that first. I've also been a little slow with planning for the holidays.
Thanks again for the map and if you have any ideas on the map sensor that would be great. I think I'm going to start checking the previous owners wiring.
Old Nov 22, 2010 | 04:25 AM
VTEC Killer's Avatar
I run a 2.4 setup with GSC S2's, 1000cc injectors, 9:1 comp ratio. I have a base map I used just to break my car in, its a 15psi base map, if your looking to just drive around and not beat on the car, it should work decent, but only use it as a band aid to get your car to a pro-tuner. Also when you get the map, make sure you define your wideband sensor, TPS sensor calibration, outputs/inputs, because no two cars are the same. Send me a PM with your email and i'll send it over to you.
