AEM EMS Get tuning help for your AEM EMS system.
Converting the car to speed density
Old Aug 25, 2005 | 11:45 AM
xiaoni420's Avatar
map/boost sensor:
Attached Thumbnails Converting the car to speed density-evo-003.jpg   Converting the car to speed density-evo-005.jpg
Old Aug 25, 2005 | 11:48 AM
xiaoni420's Avatar
one more:
Old Aug 30, 2005 | 07:14 PM
SlowCar's Avatar
Thats tight Nick!
Old Sep 10, 2005 | 09:43 PM
PPI's Avatar
PPI
Originally Posted by kcevo
Here is the thread on the AEM forum that I used to convert the car to speed density.
http://forum.aempower.com/bbs/viewtopic.php?t=80
Evo wiring:
MAP sensor:
you are going to want to tap into the MDP sensor as mentioned in the 2G install. It is on the top of the intake manifold closer the FPR. The three wires are black = ground (pin 91), grey = power (pin 81), and yellow = is the signal wire (pin 73). The AEM 3.5 bar map sensor i installed had a plug with a red = 5v power, green = output, and black = ground. Wire it black to black, red to grey, and yellow to green, if this is the sensor you use.
my aem map sensor harness has 1 unshielded wire also....does anything have to be done to that?
Old Sep 11, 2005 | 10:52 AM
kcevo's Avatar
I noticed that on the new sensors, I cut it back and did nothing with it.
Old Sep 11, 2005 | 12:10 PM
PPI's Avatar
PPI
i figured that, as it didn't go through to the actual weatherpack connector. Just when i am doing things for the first time i ask lots of questions. thanks kcevo.
The only thing left to wire in is the wideband. I am slowly getting there...
darkmitsu
Lancer Engine Tech
282
Feb 27, 2024 01:31 PM
Blak94GSX
Evo X How Tos / Installations
21
Feb 4, 2015 03:02 PM
trinydex
Jun 30, 2014 02:26 AM
Darkn3s
Apr 6, 2011 07:43 AM
ben3850
Jan 12, 2011 08:49 AM
