AEM EMS Get tuning help for your AEM EMS system.
finally dyno'd the evo w/the ems
Old Jan 25, 2004 | 10:24 PM
Wadzii's Avatar
we went down to knowledge performance over the weekend to finish up the evo we have been working on.
we had really good results.
303.7hp 314tq
all it has done is a RMR hard pipe kit, hks downpipe and exhaust, stock cat and converted to speed density. we managed to get the boost to hold fairly steady at 21ish psi, it started tapering off after 6000 rpms. the intake temps were sky high on the dyno, easly 30deg higher than what we see on the street.
ill have the dyno graph up soon
Old Jan 26, 2004 | 12:59 PM
Evo8Master's Avatar
Aem
Is that on a 4wd dyno to the wheels??? Any issues with cold starts? How is the idle? Nice numbers!!!
Old Jan 26, 2004 | 04:31 PM
Wadzii's Avatar
yep, thats on the 4 wheel dyno at knowledge performance near atlanta ga.
the car idles great. but it does take a while to start. it just seems that the car takes a few rotations to sync. no sync means no start. its kinda rough on the cold start, but i havent had much time to mess w/the cold start.
Old Jan 26, 2004 | 07:21 PM
Evo Ate's Avatar
Thats my evo that wadzii is talking about...The guys at Eurospeed in Cary, NC did a great job on road tuning and dyno tuning at Knowledge in ATL.
The car was so well tuned on the road that it only took a couple of hours to really dial it in on the dyno.
Thanks to the guys a Knowledge Performance, they were super nice and have a great shop.
303hp @6050 rpm
312ft/lb@4000 rpm
Stock turbo, stock intercooler, stock internals, Hks full exhaust, stock cat converter, rmr int. tubing, and injen air filter.
Old Jan 26, 2004 | 07:24 PM
Ryanmcd3's Avatar
In Timeout
What o2 did you tune off? because when I dynoed my evo stock the o2 was WAY off. Also my stock car on there dyno got 239.9 WHP.
Old Jan 26, 2004 | 07:33 PM
HobieKopek's Avatar
Lemme know if you ever work out the sync/start issue. Mine's very similar. Well...was. I got most of it fixed, but I'm starting form scratch in the spring when I get my car back together so I'd be interested if you have any insights.
Using an internal wideband is the only way to go. FJO and AEM both make kickass units and now both companies make them with digital/analog gauges for quick readings w/o logging or laptop as well.
Old Jan 27, 2004 | 07:17 AM
Evo Ate's Avatar
My evo was extremely rich when we first started. It was like the wideband was joking. I think it was in the mid 8's to low 9's. So we obviously picked up a lot of power by leaning it out.
Old Jan 27, 2004 | 01:04 PM
Wadzii's Avatar
we were using the aem uego installed in place of the front o2 sensor. the one on the dyno was wayyyy off. i dont like using o2's placed after the cat.
we never dyno'd it with the stock ecu.
it seems that the aem base map was way rich. not sure though, i changed it over to boost comp before we started the car.
Old Jan 28, 2004 | 03:53 PM
Wadzii's Avatar
http://www.eurospeedperformance.com/evo.htm
we got the dyno chart up
Old Jan 28, 2004 | 03:59 PM
Ryanmcd3's Avatar
In Timeout
I think they are fudged numbers, the Gain and the ratio are WAY off why did you get 6.x as the ratio lol. Here look at my chart. One of these charts is wrong.
https://www.evolutionm.net/forums/sh...ighlight=239.9
Old Jan 28, 2004 | 04:12 PM
Wadzii's Avatar
we ran the car in 3rd gear, looks like you ran the car in 4th. on the dynapack the gear dosnt matter as long as you are loading the engine up fully.
the gain is the change in numbers from the lowest curve on the chart to the highest.
Old Jan 29, 2004 | 10:19 PM
Turboholic's Avatar
great number,
i have no chance to dyno mine yet,
i have same problem on the cold start, it has to crank about 10 time before start it, but here is 5F degree outside. i am sure it will go away on summer,
supprise, Trained EMS tuner has same problem,
question:
who you mind share the map, just for reference,
also, how's stock injector handle on 21 psi, +85% cycle?
thanks for sharing your acknowledge.
Ben
Old Jan 29, 2004 | 10:31 PM
Wadzii's Avatar
the start issue isnt cold start.. its starting in general, it always takes about 4-5 cranks before it sync's. thats an issue with the sensors in the car, not the ems however.
we were not seeing much above 70-75% duty cycle at the boost we were running. its not suprising though.. considering how fast the tq falls off. im going to be working to flatten that tq curve out next time i work on the car.
i cant share the cal.. the calibration belongs to the customer, not me. if it was my personal car id be more than happy to share it.. hope you can understand. if you have any questions feel free to im me on aim. my sn is in my profile.
Old Feb 1, 2004 | 08:46 PM
topnotchevo's Avatar
315 hp at the wheels 310 fpt all stock turbo,cooler ,fuel inj.-R.D.car for Centerforce clutch here in prescott A.Z...DFX clutch by Centerforce... short shifter....full custom 3" exaust.. HKS.Race suctioning intake..,grounding kit..,Blitz D.D. bov..AEM ECU ..wideband AEM,..21lbs. boost constant . Dyno tuned on awd dyno...Dyno-comp in scottsdale AZ first time out new car 12.7 qtr. at 109.9 last friday at Firebird Raceway...Speedworld on Weds. down to a 12.3 easy ...still getting used to car... oh yea... .038 reaction time...never fast enough ...will be in 10`s by summer
Old Feb 2, 2004 | 08:12 AM
Evo8Master's Avatar
Is there any way to fix that cold start problem???
