AEM EMS Get tuning help for your AEM EMS system.
O2 sensors with AEM and AEM serial gauge
Old Apr 2, 2013 | 09:09 PM
cdupont03's Avatar
I am putting my car back together after a large build. I am using an AEM EMS Ver.1 with a speed density setup, I have a AEM serial gauge. My questions is can I use the serial gauge to monitor the AFR's? And what should be the setup of my O2 sensors? Can I hook a wideband O2 to the AEM and view the correct wideband AFR's on the AEM serial gauge? Also what O2 sensors should I have, currently my exhaust setup contains 3 bungs two on the test pipe and 1 above the downpipe. Can I plug one of the bungs or do I need all 3. And from front to back what should the sensors be i.e. wide, narrow, wide or if I can plug one would it be wide, plug, wide or wide, plug, narrow? I want a wideband setup and I want to make sure I am not throwing a CEL.
Old Apr 4, 2013 | 08:32 AM
99EclipseGSX's Avatar
Do you have a 1313 or a 1313U EMS? If it's a 1313U, a subharness comes with the EMS that allows you to connect a UEGO sensor directly into the EMS. Then, you can use the serial gauge to display the air/fuel ratio.
If you don't have a 1313U, get something like a 30-2310 AEM Inline UEGO controller, which is just a wideband controller and no gauge. Then, you can use the serial gauge to display air/fuel ratio and any other data you'd like.
With the AEM EMS, you only need a single wideband UEGO sensor (no narrowband sensor is used with a standalone EMS).
Beau
Old Apr 5, 2013 | 04:47 PM
cdupont03's Avatar
So I would only run one single wideband sensor on the downpipe and just plug the other O2 bungs?
Old Apr 7, 2013 | 08:21 PM
cdupont03's Avatar
Bump... anyone wanna chime in? Trying to get this thing back together so anyone who can help me out, would appreciate it.
Old Apr 8, 2013 | 08:26 AM
Yes, you'll just need a single sensor.
Old Apr 9, 2013 | 07:48 PM
cdupont03's Avatar
Alright well thanks for the input, I have decided to just add the regular narrowband to the rear also in the event I ever need to switch from the AEM to the stock ECU. Then just plug the third bung. Thanks
Old Apr 13, 2013 | 10:41 PM
reid-o's Avatar
You don't want to leave the narrow band connected with the AEM in place. It won't damage the AEM, but the 02 will die pretty fast without a heater. Most standalones (below 3k) don't offer heater control and hence why they don't support narrowband sensors. The external wideband controller will have its own heater circuit.
Andrew@AMS
Automotosports - Illinois
Sep 18, 2012 07:01 AM
Fourdoor
Oct 31, 2009 12:14 PM
Chris@nolimitmotors
10
Dec 28, 2008 02:25 AM
EmeryatSTM
11
Nov 28, 2008 08:42 AM
Mightygnu
For Sale - Miscellaneous Automotive
Sep 29, 2008 09:31 AM
