AEM EMS Get tuning help for your AEM EMS system.
Automaping
Old Mar 7, 2004 | 07:31 PM
Fourdoor's Avatar
Automaping
Hey guys,
I know that the stock ECU tries to keep the A/F ratio cycling back and forth around stoich (14.62:1) With my base map setup from Buschur Racing I was running very rich at cruise (11.5:1 to 12:1) and I was getting crappy fuel mileage for obvious reasons. I did a couple hours of automaping today all in the zero boost area's of the map with a target A/F of 14:1. This is just a baseline to help my fuel mileage at this time.
Now, I am sure I can run 15:1 without a problem for low load (zero boost), but how far can I push it without danger and with good results? 15.5? More? Less?
I know that on pump gas I don't want to push more than 11.5:1 to 12:1 at high boost, but what about low to moderate boost?
Any help would be appreciated!
Keith
Old Mar 9, 2004 | 12:28 PM
Wadzii's Avatar
go as lean as possible without increasing the BSFC... that is, if you go from 15 to 15.5:1 and have to give it more gas pedal to hold the same speed then you need to go back.
personally i dont like using automapping. i can tune a car faster than the automapping can tune a car.
Old Mar 9, 2004 | 05:35 PM
Fourdoor's Avatar
I set my target for 15:1 at cruise. I know that mapping on my own would work great, but I can't diddle with the laptop and drive at the same time
What about A/F target for low boost? I will be manually doing my boosted section of the A/F map, but I need to know if I can go leaner than 11.5:1 at the lower boost areas or if I should stick with the rich mix that I already have?
Thanks,
Keith
lancerrally45
May 31, 2016 11:09 AM
loppad
AEM EMS
Oct 7, 2008 12:18 PM
KevinD
42
Jul 17, 2007 12:51 PM
Fourdoor
AEM EMS
May 17, 2004 07:15 PM
