AEM EMS Get tuning help for your AEM EMS system.
Lots of cranking before starting V1, Speed Density
Old Jun 18, 2015 | 11:37 AM
jake33's Avatar
It takes a solid 6-12 cranks to start my engine. When it's cold, it's even worse. How can I fix this? Is this a common thing for V1 + SD? Changed my MAP sensor a week ago, didn't really help.
Old Jun 21, 2015 | 06:08 PM
Jetech38's Avatar
It's normal if you have a stock trigger disc.
There's a sticky in this forum: https://www.evolutionm.net/forums/ae...-evo-viii.html That should help a little.
If it's still taking too long in your opinion, the next step is to replace the stock trigger disc with: http://www.triggerdisc.com/evo12.htm
/RK
Old Jun 21, 2015 | 06:16 PM
Jetech38's Avatar
I should add that a balance shaft delete is required to use the 12 tooth disc.
Old Jun 23, 2015 | 08:55 PM
jake33's Avatar
Ill have to see if that fixes it, thanks for the info!!!!
Old Jun 25, 2015 | 07:02 PM
jake33's Avatar
Went into AEM and the 500ms and sync early were already done.
What else could cause the issue? Low fuel pressure? Clogged injector?
Old Jun 26, 2015 | 12:11 AM
Jetech38's Avatar
The trigger disc.
You have 2 options. The 12 tooth disc, or live with it as is.
*Everything I've said in this thread is predicated on the fact that your car starts normally on a stock ECU. If that is not the case, you may have other issues.
Old Jul 8, 2015 | 12:09 PM
Jsiebert's Avatar
Welcome to AEM v1 land
Old Jul 16, 2015 | 07:09 AM
itzwolf's Avatar
As already stated on Series 1 a long crank period is totally normal and the only fix is a 12 tooth trigger disc. With that modification the car will start nearly instantly after you dial in the tune. For reference I ran a Series 1 for MANY years with no adverse effect or wear on the starter, in fact that car to my knowledge still has the original OEM starter in the car.
In Series 2, AEM implemented a batch fire scenario specific to the Evo that does an OEM like startup and the trigger disc is no longer necessary. You can still run one as I have tuned an Evo with it that moved from Series 1 to Series 2. It doesn't start faster than the stock crank disc but the 12 tooth does provide better timing resolution/accuracy.
Old Aug 17, 2015 | 01:11 PM
evo8tanner's Avatar
Go to initial crank pulse in the engine start table and increase the fuel at the lower and upper temps. Also go to the start extra vs. temp table and increase the whole chart by 5-10%. Do a hot start, turn the coils off and check for fuel on plugs if they are wet.
Old Oct 7, 2015 | 05:42 PM
Bally205's Avatar
I have v1 and it starts easily
phyzy
20
Feb 16, 2023 05:38 PM
2006evolutionse
Mar 23, 2015 12:59 PM
PistenBoy
Jul 16, 2013 04:51 PM
Antonovich
Jan 25, 2011 09:27 PM
srtboostin22
16
Jan 10, 2009 09:13 AM
