AEM EMS Get tuning help for your AEM EMS system.
Problem with tune or something
Old Jun 11, 2014 | 04:10 PM
Rome-Evo's Avatar
So, I recently did an engine swap. I had gotten my car tuned by AMS and it was working great. I had it tuned with all the basic bolt ons and hks cams 264/278 and I had to take them out.
So, I drive around and my car seems to surge. I look at the aem air/fuel ratio gauge and it goes to 15 to 16 in the red range when it surges. It feels like it want to die out and has a few times. The only thing I can think of is that the car does it because the cams are no longer in and I have stock internals.
Has anyone had an issue like the one I am describing.?
Old Jun 17, 2014 | 05:23 PM
Aby@MIL.SPEC's Avatar
yeah, people who drive their untuned cars have issues.
if you swapped cams, thats a big deal, especially for drivability.
Old Jun 17, 2014 | 05:56 PM
Bhsj13's Avatar
so..... what cams are in there now? if it is not the same ones, you will need a tune. different spec cams will throw your afr's out of whack.
Old Oct 8, 2015 | 10:03 AM
Rome-Evo's Avatar
I found out what the issue was. I had very loose wiring that was connecting my AEM EMS. Now that was fixed my next problem is that my car red lines at 5500rpm for every shift. I dont know if its do to having my car tuned with all bolt ons and now that i have stock cams i can assume that is the issue or a cam sensor problem
Old Oct 9, 2015 | 11:00 AM
TheBoz's Avatar
You should post a log.
RPM
Boost
Ign Timing
AFR
Stat Sync
Timing Errors -- I don't remember the exact name
After all that, it could be a bad cam sensor. Mine failed at 130k on the clock.
Old Oct 9, 2015 | 12:32 PM
LetsGetThisDone's Avatar
you changed cams. you absolutely, 100%, need to retune the car.
CharliEvo8
Jan 5, 2025 10:14 AM
supwiddiss
Sep 20, 2017 01:55 AM
Uscbryan
11
Jan 12, 2016 01:55 PM
joeeeclark
Dec 3, 2015 08:32 PM
ryukinevo
Nov 13, 2015 12:00 AM
