AEM EMS Get tuning help for your AEM EMS system.
Evo 8 will not start
Old Sep 18, 2015 | 04:19 PM
emerica5571's Avatar
First time to post here and kind of new to tuning some of the terms lol, however i got an 03 evo 8.
Its got EMS
I had a guy whos tunes before came over and we went over some things because it was running weird.
Motor was build and only had about 1k miles on it
Drove it a bit home and injector got clogged from some old e85 sitting along time
After cleaned and bench tested put em in starts up fine.
Was idling and misfiring rough until we messed with the idle
Was running alright except kind of wanted to die at stop signs sometimes.
Well coming down one road it just died at the end of the road and has not started since.
Cranks for awhile but never turns over.
Nothing was messed with the tune since it was driving and when it died but i feel like something still needs to be adjusted.
Setup:
Built evo 8 block.
Evo 7 head fully built on Cos 272s
Intake mani and Q45 were custom fitted and has no IAC ( but was idling alright before)
COP setup and e85
Fuel pump still primes fine
PTE 6765 T4
2150 Injectors
Was hoping for some insight or maybe some one with similiar setup could send me a map from what they have so i can compare the data.
Any input is appreciated thank you.
Old Sep 18, 2015 | 05:06 PM
hattackk's Avatar
Have you checked:
Compression
Fuel
Spark
These should be the first steps to figure out what is going on. Check these and post back the results.
Old Sep 18, 2015 | 05:10 PM
Well it was running fine until it died and haven't had time to mess with it but will post the numbers if i can get them tomorrow
Old Sep 20, 2015 | 08:04 PM
detroit pistins's Avatar
Which EMS is it running? V1/V2/Infinity...etc
And is the harness intact? meaning do you see pedal %....etc
Old Sep 21, 2015 | 04:18 AM
Yea harness is intact running V1. I do see pedal percent and everything. like i said ran fine until it died but i work two jobs so do not have alot of time to spend on it. Gonna try this weekend to see why its not getting spark because thats what it seems to me
Old Sep 23, 2015 | 10:37 AM
TheBoz's Avatar
Crank or Cam angle sensor failed or bad.
Also when you are hooked to your laptop, check for stat sync = on or true
if stat sync does not go on/true then your car will not start and you have an issue somewhere.
Old Oct 7, 2015 | 04:11 PM
Was thinking the sensors may need to see how to check em this weekend, and Yea stat sync was on
Old Oct 18, 2015 | 07:12 AM
Fuel Pressure
So the fuel pressure was super low.
It was at around 10psi
Replaced the walbro in tank and now hits about 20 ish.
Still not enough enough pressure
But for some reason it looks like the guy i got it from has walbro in tank, and 2 inlince bosch 044s. So I may be removing them or just run one and swap a new one in and hopefully get more pressure.
E85 in the tank had been sitting for quite a few months so it probably wore on everything using up the rest of that gas.
Eleventy5
Lancer Troubleshooting
Aug 31, 2013 10:43 AM
geevolution
Dec 31, 2009 05:31 PM
Noize
May 12, 2009 07:01 PM
