AEM EMS Get tuning help for your AEM EMS system.
Installed EMS, Evo won't start
Old Mar 31, 2004 | 09:46 PM
cutlass73's Avatar
Unhappy Installed EMS, Evo won't start
Hey guys,
We've installed the EMS (1313U), converted the car to speed density, made sure the firmware was updated to 1.03, loaded the 1313 MAP calibration, made sure everything was set up right (sensors, etc.).
Now, the moment of truth...
Turn key, turns over longer than normal (as expected)...
Fires, sputters, dies....
We even loaded the virgin calibration from the AEM cd, and still the same thing.
Any insight as to what is wrong? Did we miss something? We read the instructions, over and over. The car will start but does not want to stay lit, and we can smell fuel. We removed #2 and #3 spark plugs and they were slightly moist, but not soaking wet. I figure it has to be something with timing, but I'm no pro by any means. Do we have to play with the engine start timing advance at all?
We don't get it. Any help would be GREATLY appreciated.
Old Apr 7, 2004 | 09:48 AM
Wadzii's Avatar
what map sensor did you use?
Old Apr 11, 2004 | 01:43 PM
bryans2k's Avatar
timing....
Old Apr 12, 2004 | 12:50 PM
QuantumEVO's Avatar
The basemap timing should work. Try around 10 degrees in your base ignition map and 15 deg for crank. Other than that, it is probably the fueling.
Mark
www.Quantum-Racing.com
Old Apr 12, 2004 | 12:55 PM
Toddevo 8's Avatar
I would sell it go back the the stock ecu
Old Apr 12, 2004 | 02:16 PM
Zensai's Avatar
yea sell it to me cheap!
Old Apr 12, 2004 | 02:24 PM
2slowevo's Avatar
Old Apr 13, 2004 | 11:04 AM
QuantumEVO's Avatar
Give us a call; we can send you a map with high driveability and work some things out if you like.
Mark
937.642.5400
Old Apr 16, 2004 | 10:26 AM
cutlass73's Avatar
http://forum.aempower.com/bbs/viewtopic.php?t=7489
here is the thread on the AEM forum. We ended up sending the unit and the 5 bar map sensor back to the vendor. Hopefully we can get something figured out.
