AEM EMS Get tuning help for your AEM EMS system.
AEM Oil Pressure sensor gone bad?
Old Feb 27, 2021 | 12:12 PM
koolzero's Avatar
My oil and pressure gauge has been working great for about 5 years and a few weeks ago it started reading 0 - 150 back and forth and then it went to just reading dashes. I pulled over and checked the dip stick and it’s showing I’ve got oil. Is it the sensor bad? I emailed AEM and they said:
Locate the sensor and use a paperclip or pick to pull back the rubber stopper that the 3 wires are passing through on the connector to the sensor. This will expose the back of the pins that are connected to the sensor.
Test between black and red. You should see between 4.9-5 volts. Anything outside of that will tell you that there is an issue with the wiring or the gauge itself. If you have 5 volts, you can move on to test between black and green. For your 150 psi gauge, you should find 0.47-0.53volts, and the gauge should show approximately 0psi at this time.
Anyone have any pictures of how this is done?
Old Feb 28, 2021 | 06:29 PM
MasterNater's Avatar
The information AEM gave you explains what you need to do. If you look at the plug on the sensor, there's a piece of rubber (usually grey in color for most AEM sensors) that seals the wiring where it enters the plug to keep moisture and debris out. Use a small screwdriver or metal pick to carefully pull that piece of rubber back from the plug, exposing the pins. Alternatively, you can slip a thin piece of metal, like a straightened paperclip or sewing needle, into the back of the plug at each pin without removing the rubber plug. This is referred to as back probing. All you're trying to do is establish a connection at each pin to test across the pins with a voltmeter. If the readings are out of spec, replace the sensor.
beelee
Nov 2, 2017 07:13 PM
Swede-TME
May 24, 2015 10:24 AM
spinner85
Jan 13, 2013 07:00 PM
nshen43
Apr 10, 2012 03:39 PM
bao
Feb 9, 2011 09:39 AM
