AEM EMS Get tuning help for your AEM EMS system.
AEM infinity with kiggly 12T crank trigger.
Old Sep 22, 2021 | 09:29 AM
Innovation-USA's Avatar
Hi, so I am need of a little bit of help with this new setup using the AEM infinity and the kiggly 12T crank trigger. New motor is primed and ready to fire but setup for the new crank tigger is what I need help with. In the setup I changed the cam/crank setup to a
(crank 12t hall and cam 1t hall) is this correct?
If so when else am I needed to do before she will fire and start? sync state is green and she will fire but won’t stay running. What else am I missing so she will stay running so I can sync the timing and do the initial break in for this new block?
Old Sep 22, 2021 | 12:28 PM
Lumpy Sticks's Avatar
5 Year Member
What are you using for the base map? If you are using the one AEM supplies, it is so far off it wont stay running on its own. Did you go through and set up all the other sensors to match what is on the engine, especially the injectors? How long does it run for and can you keep it running by cracking the throttle open?
Old Sep 22, 2021 | 12:34 PM
so the ecu already has a base map. I was already tuning the ecu with the same setup that is in the car now only differences is the motor is a built block over a stock block. Also the crank sensor is now a 12t crank trigger not a stock 2t. I had got the car running she will stay running but sounds like crap like not running on all cylinders.
Old Sep 22, 2021 | 12:40 PM
The injectors and all other sensors are already set in the ecu long story short car was being tuned about a month ago and cylinder 3 let go of the ringland! That was on a stock block and stock crank trigger. The difference now is a kiggly 12t trigger and a new built block everything else is the same.
Old Sep 22, 2021 | 04:27 PM
5 Year Member
Did you sync the crank/cam yet? It may be far enough off to cause it to run that bad. Based on your first post it sounds like you didnt.
Old Sep 22, 2021 | 04:37 PM
Yeah, timing is synced at *5 and she is starting to idle but I know she needs more help.
Old Sep 22, 2021 | 05:02 PM
5 Year Member
Check your PM.
Old Jan 28, 2022 | 06:26 AM
tunermt's Avatar
Did you get the car sorted out yet?
Old Jan 28, 2022 | 08:01 AM
Yeah, everything is good to go know it’s a long story but she runs. Desmond over at performance destination is the tuner for this setup.
tobosoerick
Jul 2, 2015 10:22 AM
Mark_L
AEM EMS
11
Sep 29, 2013 10:57 PM
propellerhead
Mar 22, 2004 10:54 PM
ferrarokid
23
Nov 25, 2003 10:43 AM
