What is the cause for this power curves?
Can anybody suggest the reason for the "knees" in the torque curves for runs 122 and 123 in this dynosheet? The run number 093 was a previous map overlaid over the more recent map. I do have a slipping clutch, could this be the cause of this anomaly? (is this even an anomaly?). Also the power and torque curves are lower in these later runs, could this be explained by the clutch condition?
Anyway, I'd like to hear some thoughts on this. I'm interested in learning what seems to work or not work in my car.....
Originally Posted by Jorge T
The knees in the Hp curve correspond to the spike in torque at 3k rpm, most likely caused by a boost spike.
I'd say the tuning is definitely the difference, and not the clutch. If you want proof to support this, go back to the dyno after your clutch install for verification. For racing applications, your car would definitely be faster with the map from run 93, as that's the area where it lands after upshifts. All that gigantic torque on the later runs will be of no use to you once you're past 4000rpm.
I'm sure the clutch is definitely what killed your 60' times. That is some gigantic low end torque, and a weak stock clutch that is on its way out would defintely slip under that kinda twist.
Originally Posted by BadazzCR
Will you post the AFR and Boost graph from the different runs. Cause different boost levels or airfuel will change the output of an engine.
I'll get the rest of the sheets posted as soon as I can get them. Of course, these dyno runs are definitely inconclusive. There is no way they can represent the true output of the engine to the wheels due to the slipping clutch.
