AEM EMS Get tuning help for your AEM EMS system.
Where do you plumb in the Air Temp Sensor.
Old Aug 1, 2004 | 02:30 PM
TearItUpSports's Avatar
Since I will be going with a MAP based control scheme for the EMS, I also need a new Temp sensor. Where is the best place to plumb it, and is there a location where I could place it in the manifold (to be more accurate)?
I plan on using the recommended GM part (AEM kit 30-2010). Do I really need a bung welded on somewhere, or is there a location where I can add this already?
Old Aug 1, 2004 | 10:31 PM
2k4EvoVIII's Avatar
I put mine right before the bend in the intercooler piping right before it runs into the throttle body. Some people say to put it in the intercooler itself but from reading the AEM forums the best place is still before the throttle body. Here is a link with a pretty good write up on the MAP, IAT, and Boost Solenoid install. I got the MAP installed pretty easy as far as the IAT and Boost Solenoid there are no real wiring diagrams for the pigtails. So you use the stock wiring harness but you dont know what is ground and what is the sending wire. Trial and error i guess. GOOD LUCK
Old Aug 1, 2004 | 10:39 PM
liquidlancer's Avatar
if your using tbhe gm AIT sensor it doesent matter what wire goes to witch (thats what im told anyway and i had it installed on ym lancer and had no problems)
Old Aug 1, 2004 | 10:49 PM
2k4EvoVIII's Avatar
Cool thanx. Ya i used all GM sensors except for the MAP i used the AEM 3.5 bar. I wonder if my IAT sensor is messed up then becouse it is reading all over the board when i start the car. You would happen to know about the GM Boost solenoid wiring do you?
Old Aug 2, 2004 | 05:38 AM
I don't believe that the solenoid has a polarity. You can wire it either way.
Old Aug 2, 2004 | 12:14 PM
mdzuricky77's Avatar
I put mine right after the the intercooler on the lower piping on the bend. I had mine initially close to the throttle body, but it was heat soaking and giving higher temp readings than there were. I just tapped a hole and used silicone to seal it up. It works great now and never heat soaks.
Old Aug 2, 2004 | 04:31 PM
propellerhead's Avatar
When you say "heat soaking", is that from under hood heat? What are the symptoms of heat soak? Running lean?
Old Aug 3, 2004 | 05:36 AM
When I say heat soaking, I mean that the piping gets heated from the engine which results in false readings to the air-temp sensor.
Old Aug 3, 2004 | 05:51 AM
Bluesmaster's Avatar
Same here.
Old Aug 3, 2004 | 06:19 AM
HobieKopek's Avatar
Mine's about 18" from the throttle body. The GM part is cheap as dirt, simple to replace, and has preset definitions in the AEM Pro software. Definitely a great way to go.
honda-guy
28
Jan 30, 2021 08:48 PM
D1andonlyantman
Dec 9, 2016 09:33 AM
LB_Reddy
Evo X How Tos / Installations
Jul 2, 2016 01:40 PM
blackevo2001
Jul 14, 2004 08:46 AM
viciousv322
Mar 25, 2004 02:50 PM
