oil temp gauge install
Old Jul 14, 2004 | 07:41 AM
blackevo2001's Avatar
jIm installing my oil temp gauge, where do I mount the oil temp sensor?
oil pan??
somebody please let me know
Old Jul 14, 2004 | 07:44 AM
ArchieBabes's Avatar
There should be a two hex beside the oil filter, you should install it there.
Old Jul 14, 2004 | 07:47 AM
2k4EvoVIII's Avatar
You got it . Except one is a hex which you probably will need a 90 elbow for the sensor becouse of the axle. But the other one is a allen wrench bolt that is perfect and no elbows needed. GIve it a try.
Old Jul 14, 2004 | 07:52 AM
alfredob1's Avatar
Allen = Hex
Hex = Allen
Old Jul 14, 2004 | 07:54 AM
you mean i gotta drill the hole near the oil filter??
im asking not about evo specifically, but most cars
thanks in advance
Old Jul 14, 2004 | 08:46 AM
modvp's Avatar
Use a 8mm allen tool to remove one the two 8mm plugs located near to the oil filter. Use that for your sending unit.
TJSAP00
Sep 16, 2011 11:15 PM
EvoIXMR
Nov 25, 2008 05:59 PM
Profoxcg
Oct 1, 2007 07:26 PM
WickedWhtMR
Jun 29, 2007 11:08 AM
CombatCQB
Oct 28, 2003 05:17 PM
