Where to route gauge wires?
Old Nov 25, 2016 | 02:16 PM
D1andonlyantman's Avatar
Hi everyone. I've just bought myself an A-pillar pod and gauges was was wondering where to route the wires into the car from the engine bay? I've got oil pressure, oil temp and boost which actually brings me onto my next question: where should I plumb into the boost hoses for the sender?
Thanks for your help
Old Nov 26, 2016 | 07:43 AM
Chris Smith's Avatar
should be a hole accessible by the pedals covered by a grommet
Old Nov 26, 2016 | 08:29 PM
4b11slayer's Avatar
Last time i checked there was no holes so drill one and order a grommet from jegs or something. Just use hole saw and order what ever size you use.
Old Nov 30, 2016 | 03:04 PM
Thanks, I'll have a look this weekend
Old Nov 30, 2016 | 05:02 PM
Turndown's Avatar
Veteran: Army
There is a hole in the firewall all the way to the left (as you look at the front of the car) behind the strut tower that you can run stuff through. You'll probably have to pull back some insulation. Inside the car you can find it up behind the glove box, otherwise up to the left of the clutch pedal is a boot that runs into the drivers side fender and you can run stuff through there as well, but you'll most certainly need a wire snake to do so.
Old Dec 2, 2016 | 06:29 PM
Akorallygood's Avatar
I just drilled a hole and filled it with silicone. Works fine for me.
Old Dec 4, 2016 | 12:53 PM
Job done. I couldn't see anywhere obvious to go while laying under the car so I took it into the wing and through with the door wiring. not ideal but it works. thanks for the help
Old Dec 9, 2016 | 09:33 AM
Teal2nnr's Avatar
That works. As was already posted, there is a handy grommet behind the strut on the passager side of the car. I have it filled with gauge wiring...etc. I hate drilling into the firewall if it's not necessary.
Tekniq
Oct 4, 2012 01:14 PM
Go_Lancer_Go
24
Dec 24, 2011 09:25 AM
sLUg_
Mar 22, 2011 08:45 PM
42revoincali
Nov 11, 2010 06:17 AM
