How easy to unistall the AEM EMS if needed to go to dealer?
I plan on installing the AEM EMS with the 3.5 map sensor now my question is how hard will it be to return to stock if needed to and also will there be traces that it has been tampered with? I just plan on bolt on's like the MBC, Upper IC pipe so the IAT can be drilled into that instead of stock, Air filter, and Turbo Back so i see nothing more then a days work at home to get that all off.
Let me know might sway my decision and also if i stick the stock computer back in it will run fine if the car is returned to stock?
Thanks
JB
Thanks
JB
Its not really that hard, just a little time consuming. There are a couple of parts you'll need to buy to convert the car fully back to stock, like the upper intercooler pipe top elbow since you drill the stock part for a sensor. There's a great FAQ on AEM's site. Check it out.
xxxevo8xxx
Aug 16, 2009 02:30 PM
Blue Evo 8
AEM EMS
21
Jun 7, 2007 06:07 PM
