Exhaust Systems 95 Lancer GSr
Can anyone suggest a good exhuast system to fit to my 1995 Lancer GSR. Obviously i want the most horsepower gain i can get without doing to much and a nice bassy sound.
Any suggestions would help and an approximate HP or KW gain would be good also.
Cheers
Cheers
i would go with a 3"from turbo back. it may not be perfect but it will give big hp jump and will be sweet for almost any turbo you decide to put on later..... i would deff go for it.... as for gains i know that rexies get about 20kw gain and 200sxs get about 25kw gain not sure if its atw or fly but ether way ita going to make a big ***ing diff.... thats just my 2 c any way, if you want a deep note perhaps get a resinator???
Have you performed any mods yet? If so what? This will change the answer, but if it is stock I feel a 2.5" will be best as going to something like a 3" will cause you to loose backpressure and actually loose performance. Now say if you had a bigger cooler, upped the boost, with even a piggy back ecu then I would say 3" without a doubt.
And Mivec, i have found that turbo's prefer a free flowing exhaust, more then a back pressured exhaust.. thats what NA cars need really, wouldnt you rather your compressor spinning more freely ?
It is possible to get too big an exhaust for a turbo however... The reason for power loss though is for different reasons. It's that you lose exhaust velocity. Air has momentum. When you force it down a thin pipe, you create a area of low pressure behind it. This low pressure then helps the turbo keep spinning and the exhaust keep flowing.
If you have too big a pipe, the exhaust just moves slowly, cools down in the pipe and causes a further obstruction for more exhaust coming out.
So there is a compromise point somewhere... In answer to the original question, 3" is safe if you're intending to up boost and power later. If not, I'd go something smaller. I have a 3" mandrel bent exhaust on a Evo VI putting out 150Kw ATWs, and I believe there's more growth left in it before I go any bigger.
Sorry everyone
I am shaking my head now, I was thinking along a different line to what I was writing. I was thinking exactly what Sunder said in regards to it being too big and the gasses not moving fast enough. I can't believe that I said backpressure, sorry guys, WTF was I thinking.I still think 3" will be too big, to start with, unless you have bigger plans in mind.
KPerez
13
Jul 21, 2008 03:34 AM
