ce dials conversion
Old Sep 4, 2003 | 07:49 PM
Dressedinred's Avatar
Yep it was on that page, it raining here (just for a change in Melb) when it stops i shall be out fitting it.
Old Sep 4, 2003 | 11:37 PM
No good fellas, hooked it all up, the pluse wire to the tacho output and the tacho earth to batter neg. Started her up, tacho worked, but the speedo said i was going 100k, the speedo moved with the revs. Tried swaping the wires over, tacho didn't work then. Any ideas?
Old Sep 5, 2003 | 12:28 AM
rexhunta's Avatar
swap the 2 wires around.. obviously youve gotta electronics speedo, and somethings aorund the wrong way..
the CC is a cable activated speedo cluster, so i didnt have any of these hassles
Old Sep 5, 2003 | 12:34 AM
Tried that, tacho didn't work then
Old Sep 5, 2003 | 02:08 AM
Mivec's Avatar
I cant see where the problem lies...are you sure you conected the correct wires?
Old Sep 5, 2003 | 05:26 AM
Tach earth to the negative on battery
pluse to the tacho output on the firewall.
Is this right?
Old Sep 7, 2003 | 05:42 PM
This might seem stupid, but do both wires conect to the rev counter, as i have it now earth went to the rev counter and the pulse went to the speedo area,
