Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Rumor of an Alcohol Injection kit.
Old Dec 1, 2004 | 02:20 PM
AMS's Avatar
AMS
it is progressive and is totally adjustable, turn on point, how much it ramps up, and a total adjustement (gain).
If the flow decreases form anything else besides the power being interrupted though the pump then that circuit will not help you. You would need a flow-meter or at least a pressure switch to be certain.
-Martin
Old Dec 1, 2004 | 02:28 PM
GTVEVO's Avatar
-Martin
Good deal, so any ideas on cost?
Old Dec 1, 2004 | 02:40 PM
kcevo's Avatar
-Martin
Ok, I see exactly what you mean. Where would you mount a pressure switch if you would add it to your system? Is the system going to be under pressure all the time and/or a constant pressure?
Old Dec 2, 2004 | 06:43 AM
99AllTurbo's Avatar
Ditto. Would like to know the price as well.
If the price isn't set yet, can you say so?
Thanks
Old Dec 2, 2004 | 06:54 AM
Nesiop's Avatar
I am curious on the setup, and if second tank, cause I just got the MR, and it doesn't have a tank in the front/No IC Spray.
Old Dec 2, 2004 | 08:28 AM
AMS's Avatar
AMS
I'm working on it..... I have had 4 AEM EMS to tune in the past week so I've been super busy, along with developing some other new parts for the EVO. I will get some pricing this afternoon.
-Martin
Old Dec 2, 2004 | 09:23 AM
99AllTurbo's Avatar
-Martin
Old Dec 4, 2004 | 01:12 PM
AutoMotoSports's Avatar
Guys, Martin had an unforseen family Emergency. He is in TX right now and will not be able to get pricing for the water/methanol injection kit untill later in the week. I appoligize for the delay everybody.
Eric
Old Dec 4, 2004 | 02:41 PM
Nesiop's Avatar
What about the tank? I now have an mr and there is no intercooler spray tank.
Old Dec 5, 2004 | 08:12 AM
Nesiop's Avatar
Bump.
Old Dec 6, 2004 | 12:53 PM
I am going to have to wait on Martin to answer that. I am sure he has taken that into consideration. Worst case we could simply add an Evo IC Sprayer tank onto the order.
Eric
Old Dec 7, 2004 | 03:56 PM
AMS's Avatar
AMS
Pricing now looks to be around $760 for the complete kit. Includes heavy duty pump, filter, controller box, modified tank, pressure sensor, custom lines, and all neccessary hardware to mount into the EVO8. This kit is a progressive controller based on boost and comes with a GM style 3bar map sensor to monitor boost. This kit had been specifically designed for the EVO8, the MR edition will need an aux tank to hold the fluid. I will need to get an MR in here to make a tank for it. We have some basic settings based on windshield washer fluid (a mix of alchy and water). I've had great results using straight methanol but tuning is a little tricky and may be up to each individual to get the best results since methanol is a fuel and spraying a lot of it will make your car run rich. You'd be suprised how much you have to lean it out when spraying a lot of meth...but also you'll be amazed at how much boost you can run on it.
-Martin
Old Dec 7, 2004 | 04:02 PM
AMS's Avatar
AMS
If you have a map sensor of some kind, for example an AEM or other speed density based setup used in your standalone, you can tap into that sensor for the water injection. In that case reduce the price to $695.00 without the MAP sensor.
-Martin
Old Dec 7, 2004 | 11:02 PM
KIDBANGA10's Avatar
how much weight does this add to the car?
Speedlimit
May 9, 2006 03:40 PM
Robert_K
Jan 10, 2006 09:01 PM
EvoTech
88
Mar 3, 2005 07:45 AM
tcarretti
Feb 26, 2005 04:15 PM
DynoFlash
Feb 21, 2005 01:49 PM
