Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
What else should I get Eric?
Old Jul 18, 2005 | 11:31 AM
RicochetGuard's Avatar
I have my GT 3071 Turbo coming. along with your WI kit
Current:
3" turbo back
Uego
boost gauge
MBC
some other stuff but it is getting replaced with your Turbo kit
I am also planning on
780cc Injectors
head studs
Xede w/ smart chip
280 cams
exedy twin plate clutch
my question is, with cams should I be getting valves or valve springs... anything like that? to strengthen up the head or is it not needed at this power level?
Old Jul 26, 2005 | 08:37 AM
AutoMotoSports's Avatar
Valve springs and retainers would deffinetly help your cause. other then that your mod path is very good. Anything to add a little security blanket is a good thing.
Eric
Old Jul 26, 2005 | 09:55 AM
Nesiop's Avatar
Wouldn't he want the bottom end done then if he is doing the valvesprings and such in order to rev high?
Or just to be safer revving to redline?
Old Jul 26, 2005 | 09:58 AM
I am not looking to rev any higher i just want it to be strong and be able to handle the power i'm throwing at it.
Old Jul 26, 2005 | 10:16 AM
exacty, Im not recomending them because he wants to raise his redline. More so for a safety issue with those aggressive cams.
Eric
Old Jul 26, 2005 | 11:02 AM
yea i dont want to raise my redline just make is stronger.
but thanks
Old Jul 26, 2005 | 12:30 PM
Ludikraut's Avatar
I thought all HKS cams were designed to run with the stock valve train and that only cams with more lift needed to upgrade the valve train...
l8r)
Old Jul 26, 2005 | 12:33 PM
Ludikraut's Avatar
Current:
3" turbo back
Uego
boost gauge
MBC
780cc Injectors
head studs
Xede w/ smart chip
280 cams
You're going down a very similar path to what I've done to my car. You will need to decide whether you want to run the stock airbox (which will mean custom fabrication of an intake pipe that can accomodate MAF, recirc BOV, and stock airbox), or running with the AMS cone intake. The cone intake will require a custom tune, but you're going to need that anyways with the kit you're going with...
l8r)
Old Jul 26, 2005 | 12:56 PM
they can run with the stock valvetrain just fine. But if you are looking to make it as safe as possible springs and retainers cant hurt. no they are not "required"
Eric
Old Jul 26, 2005 | 01:05 PM
Nesiop's Avatar
Or go ahead and drop 1800 and get AMS to do your head, then get the bottom end done at the same time and have a bulletproof motor from them. Then you can hold the power you have and reduce shift amount and rev out the 1/4 to 9k.
Old Jul 30, 2005 | 03:14 PM
freedom's Avatar
When you do springs and retainers for the Evo are you setup to do the job without pulling the head?
Also what springs and retainers do you stock? To be honest I couldn't find any springs/retainer sets on your Evo web pages.
Eric
Old Jul 30, 2005 | 04:41 PM
edwin's Avatar
HKS
JUN
Tomei
Revolver
Supertech
By what cams you have I thing HKS would be the best. for HKS Valve Springs and Retainer Set its about $500
chaotichoax
Apr 12, 2020 11:55 PM
Black_EVO_MR
Nov 9, 2016 05:10 PM
99evoVI
Feb 1, 2016 04:53 AM
TURBO_S2K
Jun 4, 2012 06:59 PM
LanEvoBL155
74
Jul 30, 2008 07:07 AM
