Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Intake Manifold Press release
Old Jul 19, 2005 | 08:39 PM
MalibuJack's Avatar
The other magic question, how easy of an install, how "Bolt on swap" is it?
(I have to assume the typical types of things to get it working) But I'd really like to see a version of someones manifold that is a direct bolt-in without losing some sensors for those of us still using a stockish ECU (Baro sensor, EGR, and enough vacuum ports for the stuff we took off, to go back on)
Old Jul 19, 2005 | 09:00 PM
midwestmonster's Avatar
Originally Posted by QAT-R
+1, what improvment will we stock turbo folks see?
+2
Old Aug 9, 2005 | 04:14 AM
MR's Avatar
MR
do u need a adapter plate for the accufab 75mm TB? Does it fits nicely to the existing upper intercooler pipe or do we need to fabricate the angle of the upper intercooler pipe to the 75mm TB?
Please advise..i am interested...
THanks....
Old Aug 9, 2005 | 08:18 AM
AutoMotoSports's Avatar
You will see gains even on the stock turbo but they will be much milder then with say a GT35R. The manifold is by all deffinition a bolt on piece. a vaccum plate at the back of the manifold carrys provisions for all you existing vaccum lines. The manifolds are made to order with either a stock Throttle body or accufab 75mm. You upper IC pipe will have to be altered due to the fact the manifold is now alot lower on the motor then the stock unit.
Eric
Old Aug 9, 2005 | 09:57 AM
MR's Avatar
MR
Thanks for the quick reply....
So if i put on a GT35r which is soon, this intake manifold will not have much increase in performance? Why will the power gains be milder for the GT35r?
Eric
Old Aug 9, 2005 | 12:53 PM
Ludikraut's Avatar
You guys should sticky this thread.
Also, sorry if this is a dumb question, but what are the advantages/drawbacks of the larger throttlebody.
l8r)
Old Aug 9, 2005 | 01:51 PM
advantages are simply more airflow and a crazy fast throttle response. other then that the only drawback I see on a larger throttle body is that it is a little harder to modulate the throttle the throw on the pedal is much smaller. Meaning there isnt much of a gap on the pedal between WOT and zero throttle. But serisously who out there drives there car anything but WOT. Lets not kid ourselves.
Eric
Old Aug 21, 2005 | 10:28 PM
EVOONYOASS's Avatar
Will this work with the Buschur 65mm throttle body?
Old Aug 21, 2005 | 11:28 PM
wilson1's Avatar
Very nice!!!!!!!!!!
Old Aug 22, 2005 | 03:07 PM
EVOONYOASS's Avatar
bump
Old Aug 28, 2005 | 05:02 PM
Knightracer's Avatar
Ordered mine a few weeks back and can't wait to get it!
Old Sep 1, 2005 | 01:47 PM
dEdiYT11's Avatar
about how long will it take for me to recieve it if i ordered it today?
Old Sep 3, 2005 | 07:50 AM
Randy's Avatar
I wonder if there would be any gains with stock TB and stock turbo with this manifold.
Let me know
Old Sep 30, 2005 | 03:50 PM
559EVO's Avatar
will it work with all sensors and vacum lines?
AutoMotoSports
Aug 6, 2020 06:42 AM
RallySport Direct
Evo 'For Sale' Engine Internals and Drivetrain
125
Jan 21, 2015 09:37 AM
Mark@AMS
49
Aug 31, 2010 07:42 AM
AutoMotoSports
66
Jul 28, 2008 07:34 PM
AutoMotoSports
Jan 16, 2007 04:18 PM
