Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Need coilover setting & clutch advice for drag racing
Old Jul 13, 2006 | 01:22 PM
Smogrunner's Avatar
I just got retuned (click here for thread) and am ready to go to Cal Speedway on Saturday. How should I adjust my coilovers: super stiff up front and full soft on the rear? Shouldn't this help reduce wheel hop in the front and allow the back end to squat? I'm really guessing here so any help would be greatly appreciated.
Second: When leaving the line, how slowly do you disengage the Exedy Triple carbon clutch?
Third: I have my launch control set at 6000 and with this setting, I am able to build about 8 to 9 psi. Does this sound like the right RPM?
Finally, I have the rev limit set at 8100rpms, so regardless of how good the car runs, I will be limited to about 130mph. (I sincerely hope to reach that mph, but who knows ) Any comments on this?
Old Jul 13, 2006 | 10:20 PM
AMS's Avatar
AMS
Good numbers!
On the 2.3L you can run it up to 8400-8500rpm for limited drag runs. We run our 2.3L road race car at 7850rpm all the time and she's doing good so far.
Launching the car is all practice and finesse, it must take getting used to, especially on a high horsepower car. As far as the suspension settings go it would seem you'd want to rear to squat under power and stay down, not bounce back quickly. Do you have two way adjustables or one way? If two way, I'd crank up rebound and lower compression in the rear.
Hope this helps!
Old Jul 13, 2006 | 11:47 PM
Dustin@Vishnu's Avatar
The squat rates on the evo our laughable at best. The amount of weight that is transfered from the front to the rear of the car is very minimal when traveling in a straight line. (There is a way to fix this, that we are doing on the drift car)
I would try your normal settings, and then 2 clicks stiffer, and 2 clicks softer, and all of the permutations of that. See which one gives you the best results.
Old Jul 16, 2006 | 01:07 PM
Smogrunner's Avatar
Got some results. On my second run I blew off my AMS LICP (my fault - crappy clamps) and literally ran it over. If anyone over at AMS feels like helpin' out, I really need a replacement for good price...
Anyway, ran an 11.1 on my first run. Details here: https://www.evolutionm.net/forums/sh...d.php?t=211907
