50Trim + METH = OMG
Originally Posted by rocket900rr
Yes I did dyno at AMS earlier this summer when I got the JUN 264 exhaust cam, the FMIC & piping, injectors, & fuel pump - fuel rail. It put down about 335awhp & the torque was within about 15lbs. of the awhp (another supposedly conservative tune). I dont think the cam gave it more power but it definatly helped quite a bit on the low end power exspecially b-4 the boost kicks in. I cant tell if the FMIC did anything, but it has alot more volume than the stocker so Im sure it has knocked down heat soaking issues alot (its gotta be better than the stocker during repetitive boosting). Also the AMS FMIC looks KILLER sweet!!! I reccomend both the cam & the FMIC for those who must mod!!!
Originally Posted by joek84
u still on the stock clutch?
wow! full 27psi at 3500rpm!! thats very responsive! Now u make me wonder is there something wrong with my car! the 50Trim i had only see full boost of 24psi at around 5k rpm!
those are good questions.... on my car it seems like it only goes nuts to redline after 4500 RPM's at WOT...
but at 3500 rpm it seems to me thats too much boost at such a low rpm.... sounds like turbo surge....
All I can say is lets go for a ride. Guys, remember I also have Mivec. It has gotten cooler in my area so today I turned the boost back down a little to max @ 26PSI. In fourth gear my gage was reading 26PSI @ 3700-3750max rpms NO-BULL. In 4th gear Im already boosting about 5PSI by 2800rpms. The 50trim starts spooling @ the same rpms as the stock turbo did with a TBE on my IX. It doesnt start pushing you back in the seat really hard till around 3900-4100rpms & on up, but the gage is pegged at the set limit at least 200-300rpms before that. I dont know why mine spools so quick!! Is it the cam? the tuner? the Mivec? The meth? Anyway I like it & am happy with it, thats all that matters.
