Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
50Trim + METH = OMG
Old Sep 11, 2006 | 06:26 PM
  #76
EnJaNir's Avatar
We def need to meet up sometime this week or weekend. I need to check this ride out.
Old Sep 11, 2006 | 06:34 PM
  #77
Jimithing60089's Avatar
Going to AMS anytime soon? I would love to tag along for a joy ride. When I win the lottery I will be getting an ams turbo + meth, until then I will have to be happy with what I have
Old Sep 12, 2006 | 01:17 AM
  #78
EvoRecordSetter's Avatar
Originally Posted by rocket900rr
Yep, still on the stock clutch. Ive only got about 6 launches on it since new (2 so far with 50trim). Knock on wood no problems.
what do you have launch control set at? and how did you do it? dump the clutch? slip? i mean its different from the stock turbo, curious how you did your launch with a big turbo on stock clutch. did it rip out of the hole? or bog or what?
your name is 900rr, i assume you have a big or know guys with bikes, how does the car hold up with bikes from a roll?
sorry for all the questions
Old Sep 15, 2006 | 06:05 AM
  #79
Ang Wen Yan's Avatar
Use your comment sense.A 477whp 3200lbs car will keep up with a 21st century 1000cc bike??
Old Sep 15, 2006 | 06:43 AM
  #80
sorry next time ill use my "COMMENT" sense.
Old Sep 15, 2006 | 06:49 AM
  #81
Creamo3's Avatar
I believe the word you were looking for is "common sense"; and while an Evo may keep up the power to weight ratio is in favor of the 900RR. As a 12 yr old poster I'm sure you have ridden many large liter bikes in your day to know this already though.
Modded Evo= 477whp/3200lbs = 6.7lb/hp.
Stock 900RR= ~110whp/~400lbs= 3.6lb/hp.
Old Oct 7, 2006 | 08:34 PM
  #82
boomn29's Avatar
Also its a IX so the mivec probably helps with the fast spoolup too. Honestly it spools just as soon as the stock turbo. It holds boost alot better with almost no boost droppage by redline (could be due to the TIAL Wastegate & GREDDY Blowoff valve???). As far as meth usage goes, the meth starts pumping when I hit 8 PSI of boost. Im guessing that for 1 minute of being in boost at 8 PSI or more I use about 1 1/2 gallons of meth. Its hard to have 1 minute of boost time during my average commute or rant around town so its not too costly meth wise. I got 10 gallons of VP Racing M-1 (meth) from AMS when I picked up the car, I think it was about 35-40 bucks for a nice 5 gallon can. I try not to drive in the rain so finally my windshield washer tanks gets some use...
Would it be insane to use meth on a road-race course? I mean where you're pretty much either on the brakes or in boost for 20-30min? Is that even possible to last and/or just too plain costly?
Old Oct 7, 2006 | 08:45 PM
  #83
Doogie Howser's Avatar
I think it would be much easier to disable your meth system (pull out the fuse) and then reflash your ecu (use ecuflash) using a race gas map.
This setup is great. The mivec + 50 trim + alky must be heaven.
Old Oct 9, 2006 | 08:04 AM
  #84
AutoMotoSports's Avatar
in a road race senario I would run race gas and turn the meth off.
ERic
Old Oct 13, 2006 | 11:35 AM
  #85
94AWDcoupe's Avatar
I sure would like to see this dynograph. Can someone post it in a different format? Any track update on the car?
Old Oct 24, 2006 | 10:54 AM
  #86
MICLOIV's Avatar
would having a AMS VSR intake manifold help out at all with this setup?? sorry dumb ? but just curious.
Old Oct 24, 2006 | 11:28 AM
  #87
KevinD's Avatar
not exactly right:
modded evo = 477 + 3200lbs w/driver and gas = 6.7lb/hp
900rr = 110 whp + 600-650lbs w/driver and gas = 5.4-5.9 lb/hp
driver weight is a huge fraction of the total weight on a bike. if your a fatass, you will go much slower then someone who is a twig.
do some weight reduction on an evo to say, 3000 lbs/wdriver:
6.3 lb/hp at this point it is almost a drivers race. aerodynamics will play a huge part in a high speed race.
Old Oct 24, 2006 | 11:37 AM
  #88
SterlingEvo's Avatar
^that's what I was going to say adding a 200lb driver to the bike changes the p/w by 50% up, whereas even a 350lb driver in an Evo only adds 10%. And that's an even bigger dent out of 110hp than it is out of nearly 500...
Old Oct 24, 2006 | 12:51 PM
  #89
BillAce's Avatar
Bikes are usually drag limited and have higher top speeds than an Evo so the slight hp/weight advantage over the Evo is more than enough even with an older bike. My CBR weighs 542lbs with me on it and has 173hp to the rear tire (3.13). My Evo weighs 3268 with me in it and has 352awhp (9.28). I know what I choose when I want to go fast.
Old Jan 16, 2007 | 11:24 PM
  #90
Saotome9's Avatar
very nice!
