There is a local here that is running a 10/1 2.4 liter with 37r. he runs two sets of injectors. second set is c16 set. Currently being tuned. He had a meth setup but wasn't happy with fuel mixture problems. Mixure gets richer and richer per gear. I am anxious to see the results. I have been wanting to switch to spraying ethanol via a second set of injectors. This would give more precise control over injection. Methanol through injectors is too corrosive. Just cant find ethanol anywhere here in tampa.
What about tuning a car on straight C16 vs. 93 with meth? Which would put out more horsepower? Can you run more boost with C16?
Yes a C16 tune will net you more hp and allow for more boost.
Eric
Eric
What would be interesting is mixing 50:50 methanol/nitromethane and spraying that. You might get the cooling effect of the alcohol and the super firepower of the nitromethane.
how bout instead of 93+meth use C16+meth, what kinda results would that show for a 50 trim.... doesnt curt brown do that?
Quote:
Eric
is MS 109 leaded or unleaded?Originally Posted by AutoMotoSports
we stock MS 109 here at the shop. Its what we run in our Time Attack car.Eric
