Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
awd please
Old Sep 14, 2006 | 02:58 PM
1_900hustler's Avatar
awd please
I bought a used evo 8 a while back, and in my hast failed to realize the rear leg of the drive train that connects to the rear diff was missing!!!
My question is,
1. am i damaging the car futher by leaving it FWD
2. If I buy a used third leg will that be all that is required to restore AWD.
3. And if i would need to do more, what??
thanx in advance -bravo
Old Sep 14, 2006 | 03:30 PM
Tristar's Avatar
Buy a drive shaft and connect it to the rear diff. See what happens. No one here can diagnose anything else without more info and/or pictures. If you want my guess, Id say they disconnected the drive shaft because of a rear diff issue.
I think the bigger issue here is you buying a fwd Evo without noticing....
Old Sep 14, 2006 | 03:41 PM
cfdfireman1's Avatar
Aren’t you the guy Al tuned a while back and he did a front wheel burn out that was video taped? What happened to the law suite?
Old Sep 14, 2006 | 03:43 PM
emagdnim8's Avatar
You bought a front wheel drive evo
Old Sep 14, 2006 | 03:52 PM
revvin9k's Avatar
Old Sep 14, 2006 | 04:19 PM
yeah im the same guy..... i won the suite but they only cut me cash for what the part would be worth.....
being that i was going for so much more
as for not knowing it wasnt AWD, another prob was it didnt have a boost selenoid at first either so i was only runnin wastegate pressure. barely enuff torque to get the tires loose... +im am a newbie to turbo cars in general
Be easy i feel ****ty bout it already
Old Sep 14, 2006 | 04:23 PM
Tristar's Avatar
Ok, no problem. My advice would be since your new to turbos, and cars in general (mechanically), find a good local shop and go over the entire vehicle. Ask to look it over with them, you will learn alot and get a better idea of what is all missing from the car.
Or ask local Evo owners to check it out. Im sure someone would lend a hand.
scott yo's Avatar
a front wheel drive evo haha that is crazy!
Old Sep 14, 2006 | 04:52 PM
Are you sure it's just missing a part and not something wrong with rear dif or transfer case? I don't think the shaft just fell off it was removed for a reason.
Old Sep 14, 2006 | 05:00 PM
yeah im sure its missing..... ill post sum pics tomorrow..... but i was just under the impression that maybe there was a carbon fiber piece that was removed b4 it was traded or maybe it had to get towed and there was no flat bed availible idk
Old Sep 14, 2006 | 05:01 PM
AdamJ39's Avatar
Having built 2 FWD mirages, and an AWD mirage, i can tell you that the car will not run FWD reliably without having the center diff welded in the tranny, if its not welded, the car will Eat the viscus coupling, you can tell if its doing this by the way it accelerates, if you start off and the car is totally pathetic (similar to having a dead clutch), then the diff is not welded, and chances are that by now you've ruined the viscus, you might as well plan on buying a new tranny to get it straightend out or talk to Jon @ TRE and he may give u a better solution, if the diff was welded then you'll also basically be looking to replace the Tranny, either way it sounds like at least you'll be changing that
-Adam
Old Sep 14, 2006 | 05:04 PM
Yea that^^^^
Old Sep 14, 2006 | 06:08 PM
-Adam
well thanx for that.. sounded concrete (like u kno) well i have a boost/c , exhaust, and dynoflash custom and when i get traction she aint slow at all.........so im more than likely welded now what ?????
Old Sep 14, 2006 | 06:17 PM
Back to court!?
"Be easy i feel ****ty bout it already" Just trying to help ya bro.
Old Sep 14, 2006 | 06:22 PM
Back to court!?
futher action would be hella $$$$$$$$$ and im in the military -bravo
