Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
AMS Alky kit
Old Sep 30, 2006 | 01:05 PM
Evolving03's Avatar
AMS Alky kit
Is there a failsafe on this kit? Don't see anything about it on their website and haven't been able to find anything here. For those of you that have the kit, how do you like it?
Old Sep 30, 2006 | 02:44 PM
smokedmustang's Avatar
Love It!!!
Old Sep 30, 2006 | 06:02 PM
vjz225's Avatar
whats the diff. from ams kit and the smc ?
Old Sep 30, 2006 | 06:31 PM
It used to be pump size,(AMS larger) and one you can run strait meth thru (AMS), and the other you couldn't. That rule may or may not still apply. It was that way last year when I got mine.
Old Sep 30, 2006 | 08:19 PM
Tim@AMSperformance's Avatar
There is a pressure switch that changes the activation led from red to green when 30psi has been reached so you know that the system is working properly. Also that circuit offers an output to trigger a input on a standalone or other limiting device
Old Oct 7, 2006 | 08:31 PM
boomn29's Avatar
So the AMS kit can be setup to pump alky or meth?
Old Oct 9, 2006 | 08:09 AM
AutoMotoSports's Avatar
that is correct.
Old Oct 9, 2006 | 05:51 PM
lcakes05's Avatar
would you reccomend a wide band for this kit?
Old Oct 9, 2006 | 06:15 PM
WHo is this question for? I would say YES, I have the AEM UEGO.
Old Oct 9, 2006 | 10:47 PM
it is always a good idea to have a wide band when introducing an extra fuel source to your setup
Old Oct 10, 2006 | 06:50 AM
A wideband guage should be one of the first items you buy for your car. It can be the difference between a blown engine or one that is out of tune and corrected.
Eric
Old Dec 17, 2006 | 10:31 AM
MitsuJoe's Avatar
Ok to spice it up a bit more why should I buy this kit say over the SMC or the Aquamist?
This output to trigger an input could you please explain?
Also why does your kit use a MAP sensor? If I already have one is it safe to allow the MAP sensor to output to 2 different sources. Will this drop the voltage or would it be ok?
Old Dec 17, 2006 | 03:06 PM
03silevo's Avatar
yeah how much does this alkie kit runi dont see it on your website at all and im really interested in getting one and does it have a failsafe system? and also can you run it on stock ecu thanks
Old Dec 21, 2006 | 01:35 PM
GT35REVO8's Avatar
so with meth/alky you should get a wideband gauge..?what if your AEM has a built in wideband?
Old Dec 21, 2006 | 07:55 PM
Joshs EVO's Avatar
I don't understand much about this Alky/Meth stuff but I need/want the horsepower and that's a way to do it after I do most of the bolt -ons. So I have heard about this Snowman or something Snow kit. I heard it is the best kit. Although I have most of my stuff from AMS and would like to stay with them. So how much Horsepower you think I wil push after I get one of these kits. Right now I have full Invidia Exhaust, HKS 272 cams,cam gears, AMS UICP, LICP AMS FMIC, small battery kit.
