Wicked sick...I can't believe you guys stripped it bare...but that's the only way to go.
So lemme guess, full bead blasting, seam welding, chamfering of certain areas and a full cage?
As for Time Attack, are you guys planning on taking on Tarzan Yamada and the Cyber Evo?
One quick ? to AMS.
Did you guys cut out the extra steel that is sandwiched inbetween the B-pillars? It removes about 40 pounds from the wrx (unsure about the exact weight for the EVO). This removes more weight and is cheaper than a carbon roof and is undetectable if that even is an issue.
The car is still at the acid stripper. When it comes back we will be working on removing everything that does not make it fast or sacrifice safety. The area in the b pillar is going to be looked at very closely. There are 4 sheets of steel in places in that area. We are considering intigrating the cage into the b pillar. We have tons of ideas that will all be explored when the car returns.
Looks like I am going to have some more competition for Winged Warrior this year. Hopefully You guys will be able to defend 1st and I will be able to do better than 3rd.
Quote:
doesn't that make the metal like really weak so if you lean on it. it can like crumble it?Originally Posted by 9sec240
I hope we get to watch this build progress on here, would be very interesting to watch.
Curious about the roof, keep us posted.
Quote:
No, the acid dipping solution is semi mild as far as acid's go. While it will remove some material the amount is pretty minimal. It wont make the metal any more brittle just nanometers thinner.Originally Posted by mike1023
holy god ams ur really goin all out wit this one, omg keep us updated nd il love u
Gary's car is close but Ill leave all updates to him
As far as Tattoo is concerned she will be a full blown race car. Honestly The first we have built to this level. We are really trying to show off what this shop is capable of with this car.
Eric
Eric
wow thats gonna be a lot of work... if you need help putting the tail lights in that might be the only thing i see that will just fit right in with no problems lol
any eta... or should we say before the ice melts?
good luck!
good luck!
wow... i know you guys want to go light.. but taking the engine out and the seat and everything else.. thats just unheard of... whats the hp gains running no engine>?
