Which is better/safer? E85 or meth?
When it boils off, where is it going to go??? Its going to condensate on the inside of the engine and drip back down into the oil, and when it mixes in the oil it breaks the viscosity down. I am the one sampling it for him, the results will be back next tuesday. I can't really say what happened yet but I will say this, his oil was very thin and if you are running e-85 you should change your oil every 300-500 miles if your running mobil 1. Im still doing research on how e-85 breaks down oil and I will post the results when im done.
For it to condensate and go back to liquid the temp in the motor must be all the way cooled down. when the ethanol goes from liquid to gas it expands and this would make some pressure so before the iron block gets cooled down to the point where the ethanol goes back to liquid i think it would go out the crank case vent i have not taken my evo's crank case vent apart but i am sure it is better then most N/A cars which have been making do with E-85. i know what ethanol does to oil i have been doing research on Biodiesel production at the company i work at. But the ethanol or methanol alone will not brake down the oil it will cause some separation but the ratio of oil to ethanol is very high. Btw Methanol is the choice when making biodiesel because of cost and is much better at braking down the oil chains when mixed with sodium methoxide.
Here is how most of the honda guys vent the little turbo motor's
This would also work as a still and collect all the ethanol in the catch can.
Prosdoc
Jul 1, 2015 03:33 PM
