Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Why AMS recommends Race balance shafts
Old Jan 16, 2009, 08:44 PM
vboy425's Avatar
^^^yep it stills uses the belt. which if the belt snap, big problem. Also the reason why people eliminate the balance.
1: Zero chance the B-Belt will fail and kill the timing belt
2: Zero chance the balance shaft bearings will fail and all the shaving will get throw vy the balance shaft to the crank and damage the rest of the motor.
Old Jan 17, 2009, 02:40 PM
Scottr126's Avatar
I don't mean to be rude but your information is completely incorrect.
With the AMS race balance shaft kit the belt is eliminated along with the shaft that was driven by it. We have the counterweight machined off of the shaft that is driven by the oil pump. Once that is done it can be re-installed so that you have all of the support of the full balance shaft without all of the weight.
Old Jan 17, 2009, 03:03 PM
cpoku's Avatar
Do you have any pics of this installed?
Old Jan 17, 2009, 03:45 PM
Scottr126's Avatar
Here is a link to the kit in the new store, I dont have a picture of it installed at the moment.
http://www.amsperformance.com/cart/p...cat=658&page=1
Old Jan 17, 2009, 05:27 PM
edardnaekim's Avatar
New site looks great! Someone posted previously about this not being so great on a stock ecu car (false knock i assume) your thoughts?
Old Jan 17, 2009, 08:21 PM
dryad001's Avatar
$300 for something that can be done in 5-10 min on a lathe? Glad I did it myself.
Old Jan 17, 2009, 09:02 PM
Gordian79's Avatar
last time i checked most people dont have a lathe.oh wait ill go out and spend 1k on a lathe and do the job myself in 5-10 min.
Old Jan 18, 2009, 12:06 AM
1badgsex's Avatar
u can go to any machine shop (preferably a well know one) and get this done, iam a machinist and this "mod" would not take long at all on a lathe.....
Old Jan 18, 2009, 01:46 AM
vboy425's Avatar
my bad in belt info. Scott.
but it still doesn't eliminate the balance shaft bearing failure and throw shaving on the crank. i'm right or wrong ?
Old Jan 18, 2009, 07:52 AM
Scottr126's Avatar
One bearing is still being used but its fed oil directly from the oil pump by the balance shaft so it is very unlikely. But then again the crank or rod bearings are being used to. Technically anything COULD fail.
Old Jan 18, 2009, 01:37 PM
NewCalEvo's Avatar
sorry for the picture quality, it wasn't taken for the purpose of showing that part specificaly, but you can still see it .
Old Jan 19, 2009, 10:46 AM
Scottr126's Avatar
Alright guys I updated the store page for the kit. The kit is sold on a core charge basis so if you can send in your good balance shaft then the price of the kit is $150. The kit can still be bought outright for $300.
Old Jan 27, 2010, 08:35 PM
Fast Frank's Avatar
On the website it shows $164.95. Also what is the purpose of the "Pulley Eliminator" Option? I don't see any details of this on the website. Thanks!
Old Jan 27, 2010, 11:45 PM
tumtum411's Avatar
another great job from ams
Old Jan 28, 2010, 06:28 AM
Scottr126's Avatar
The pulley eliminator is a spacer that goes in place of the balance shaft pulley that is on the crankshaft. It weighs about 1/4 of what the full pulley weighs.
Quick Reply: Why AMS recommends Race balance shafts
