Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Question on solid rear diff bushings....
Old Jan 28, 2008 | 07:53 AM
EvoIXMR's Avatar
AMS Team - I am getting ready to have the bushings on the rear diff "ears" pushed out and run the solid ones...
I was wondering if I need to re-use the cup shaped piece on the bottom end and the rubber piece on the top end?
Does the solid bushings replace all of it and the bolt go straight thru into the body/subframe? I am just wondering if a flat washer should be used or something to keep the bolt from getting pulled thru? Hope I am making sense.
I can post pics if that helps explain what I mean.
Thanks!
Old Jan 28, 2008 | 11:02 AM
Tim@AMSperformance's Avatar
you do not use the the cupped shaped washers. Yes the bolt goes directly through the solid bushing
Old Jan 28, 2008 | 11:50 AM
EvoIXMR's Avatar
Thanks....
So, I don't need to use the thin rubber piece as well, right?
I hate to sound **** - I am worried bolt will pull thru, I may add a round washer to be safe. It shouldnt affect clearance or bolt depth. I want to distribute the bolts load on the bushing...
AMS - Anything wrong with my approach? Thanks!
Old Jan 28, 2008 | 12:03 PM
no rubber washers. Torque the bolts to like 75 ft lbs and youll be fine
Old Jan 28, 2008 | 12:10 PM
EvoIXMR's Avatar
Thanks for answering this, I appreciate your help!
meckert
Sep 9, 2016 09:53 PM
windsorevo4
Aug 9, 2016 01:45 PM
wiggam11
Nov 22, 2015 03:13 PM
blockade35
Nov 16, 2013 04:30 PM
BoostedAWD91
Oct 17, 2013 07:30 PM
