ams mustache bar delete
Old Nov 13, 2008 | 06:43 PM
wiggam11's Avatar
i'm running it, felt real solid no clunk at all first then a little bit here and there has a slight clunk on a fast shift without easing the clutch in or if i am going up a hill on boost or load then pop in the clutch quickly, just thinking the allen head bolt might be a little loose and when i installed it i just used the supplied ams bushings i noticed between the rear diff ears and there it mounts to sub frame there were 2 rubber circular spacers i didn't re-use them since i think the ams ones replace them just seeing if anyone has had their ams rear mustache bar delete vibrate loose at all
Old Nov 13, 2008 | 06:44 PM
nothere's Avatar
for the love of god man, periods are free.
Old Nov 14, 2008 | 03:44 AM
EvoDan2004's Avatar
Nothere
Way to help the guy out.
Wiggam11
What you are experiancing is probably normal. When I installed mine I also here some clicking and such. I think its the diff just being solid to the rear of the car. So you will here and feel all kinds of stuff. But for safe keeping get back under the car and make sure everything is all tight and inspected. Otherwise your fine my man.
Old Nov 14, 2008 | 04:23 AM
I4UnderPressure's Avatar
On a side note, I'd be curious to here if your bolts came loose or not. I know mods like that are good to be checked once in a while for tightness. Let us know as I too am thinking of doing this mod.
Old Nov 14, 2008 | 05:40 AM
nothere's Avatar
wiggam, sorry, guess I had a bad day at work and my eyes were tired.
Old Nov 14, 2008 | 01:56 PM
wiggam11's Avatar
hey no hard feelings thanks for all the input. Just don't want it to be something major i already had to replace the clutch 3,000 miles after i bought it. this is a little off topic but i launched me car a while back from 5500-6k with a slip def not popping the clutch and it blew the freeze cap or plug off the water pump. The dealer replaced it under warranty and decided to do my timing belt balance shaft tensioner as well. question is why would that plug or cap pop off , dealership said it was defective, but it c ame off right after the launch. i saw all my coolant pretty much a little after wher ei launched ot where it almost all dumped out. Just want to know what would cause that. And i will check the mustache bar delete. i used some periods this time haha
Old Nov 22, 2015 | 03:13 PM
krisdlm's Avatar
Delete
4b11slayer
21
Jul 18, 2017 03:14 PM
kaj
Feb 6, 2017 07:31 PM
krisdlm
Mar 21, 2016 04:43 PM
Vladj
Feb 10, 2016 09:34 AM
kaj
39
Jan 27, 2016 12:19 PM
