The AMS Genesis coupe is HERE!!! Let the modding BEGIN!!!
So I just test drove a 2010 Premium coupe, and new Raliart at the same dealer, I for one found the Genesis much more fun to drive, and the push start is great. The raliart felt "big" and the whole paddle shifting, sport mode, normal mode. is to much junk, lol the Genesis was even $2000 cheaper. might get one.... Thanks Ivan!! lol
Also please if you are in the midwest and considering picking up a Genesis coupe please make sure you check out Gartner Hyundai in Aurora, IL. Phil and Eddie really took care of us over there. The best part is everyone there has a true vested interest in seeing the real potential of this car http://www.gartnercars.com/
LET THE MODDING BEGIN!!!
Eric
Eric
This seems like a hyndai I wouldn't mind driving.
Suprisingly it responded very well to the boost controller, and didn't even cut me off until about 18.5 psi. Once it hits the boost limiter though, you have to shut the car off and turn it back on or it opens the BOV and refuses to run any boost!!! The MBC definitely smoothed the boost curve out quite a bit, and it does seem like the power delivery would be more linear on the street. I can't wait to get into these ECUs and see what they will really do!
no but it has a vacuum bar(plenum or whatever you wanna call it) which is controlled via the ecu so the BOV can be held open via the engines computer telling it to do so (limp mode), the only way to reset this would be the restart the car...SRT4's have the exact same setup...its so that if for some reason the car over boosted heavily it wouldnt let the car blow the engine, and it wont let you boost afterwards since it thinks whatever caused the situation is still present (ie. the weather)
waiting for boost controller, fuel pump(if needed), TBE, intake, IC piping, new intercooler (as that baby looks so inefficient and probably get heat soaked super fast) numbers!! I'm sure being a Hyundai there are lot's of restricitions/silencers/heavy sound deadening to keep the drive reliable for everyday driving, not our style of driving...
Quick Question what kind of turbo is it?
Just to make things clear...
This second round of dyno were started 100% stock again. I had removed the boost controller after our first round of tests. Tests included a baseline 87, baseline 93, baseline 93 after ECU reset, intake silencer delete, intake silencer delete and secondary cat delete, intake silencer and cat back (secondary cat reinstalled for this test).
Tony, Greg and I fabricated a 3" stainless down pipe / mid pipe combo last night and got started on an IC and IC piping. I am hoping to stay late tomorrow night and finish this up. I had a nut seize on a turbine housing stud and had to cut the stud. I need to pull the turbo off to drill the stud out so I am not going to get it on the dyno till probably Saturday.
I am hoping that one of those two items is the big cork that will let this thing breathe.
In my opinion its the turbo that is restricting the power.
Its tiny and isn't running alot of boost.
Changing the exhaust / intake / intercooler / etc I feel wont increase HP much because they are probably flow sufficiently for the tiny turbo from factory. Change the turbo (would be cool if the stock twin scroll X turbo could fit) and see the difference.
The primary cat has the tightest brick I have ever seen. Tiny tiny tiny little tubes through the brick. I wouldn't be surprised if the net area is less than 2". I am pretty sure the 3" down pipe will improve spool and increase HP.
