Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
AMS Lower Intercooler Pipe problem:
Old Apr 21, 2009 | 11:23 AM
Bear.914's Avatar
Okay I noticed that the pipe got damaged by a bracket under it piercing a hole into it I guess from normal driving vibration or pressure and was just wondering if this happen to anyone else with the AMS lower pipe. It kind of sucks that a rounded piece of metal pierced a hole through a pipe that cost over 290.00 in such an easy manor. The pipe was Installed Correctly 110%
Old Apr 21, 2009 | 05:02 PM
AutoMotoSports's Avatar
can you take pictures of it installed on the car? What bracket in question rubbed through it? The reason I ask is nothing should be in contact with it when installed properly.
Pictures would be great. Thanks!
Eric
Old Apr 22, 2009 | 07:04 AM
Bear.914's Avatar
Eric
Pictures will be back up soon, cars at mitsu. at the moment but they showed me the punctured hole and I asked them if the pipe was in there correctly and they said yup!...im not here asking for a new one guys but it sucks lol just trying to prevent it from happening with other members..it sucks its bein on for like 2 weeks only lol
Old May 17, 2009 | 10:06 AM
Mtandre21's Avatar
Wow hope you could get it fixed.
Old May 17, 2009 | 10:33 AM
houdini_678's Avatar
Mine is holding on; no issues... Good Luck.
Old May 17, 2009 | 11:30 AM
4wdrifter's Avatar
i noticed mine doing the same thing a little, caught it before it wore all the way through though. it was rubbing on a screw on my beatrush underpanel.
Old May 25, 2009 | 01:51 PM
Bear.914's Avatar
its pierced through from a metal mount holding a coolant hose
Old May 27, 2009 | 10:06 AM
Bighec's Avatar
Any word on this from the man?
Old May 27, 2009 | 10:21 AM
linuxman51's Avatar
hehe, the licp on mine blew completely off and got run over a couple weeks ago, that issue has since been corrected.
I have to ask tho, has it been redesigned in the past.. mm 3 years? the piping that came with the 35r kit seemed to be a bit longer than required as well as well as not having any kind of bracketry to hold the thing up in the event of a forceful separation :-D
Old May 27, 2009 | 10:32 AM
We have not heard from the original poster.
As far as the GT35R lower pipe it does not have any bracing but we do recommend that T-bolt clamps are used. To be honest we rarely ever have an incident.
Eric
Old May 27, 2009 | 07:25 PM
Bighec's Avatar
I am not the original poster, but I did send you guys an email earlier today about some things.
Old May 31, 2009 | 05:16 PM
Bear.914's Avatar
I didnt take pics but the hole was as small as a penny, and it was cause from a metal bracket holding a coolant hose in place from my own knowledge. I guess ill just leave the stock one on.Once again this thread wasnt made to bash AMS but maybe to prevent other people from having this problem or AMS to see if there is any possibility of this being a problem.
Thanks, Bear
Old Jun 1, 2009 | 10:44 AM
I would really like to see the pipe installed and the piece as it was rubbing through it. We have never had this problem before.
Eric
Old Jun 1, 2009 | 12:44 PM
Bighec's Avatar
Here are some pics of mine. It also rubs against the bracket for the lower radiator hose. Today I took it off, and tried to find a way to mount it without the rubbing, but no matter how you put it once you mount the bracket, it pushes the pipe into the coolant hose bracket.
Pic from above.
This pic shows where the pipe hits the bracket. It makes contact just above the clamp.
Here's a close up from above.
I am no engineer, but I think that the bracket that mounts the elbow on the lower pipe to the chassis might be to short. Another thing, where the bracket mounts to the chassis for the lower pipe, there are two holes, I mounted on the lower one, I tried to mount it on the upper one, but I couldn't make it happen. Any insight would be greatly appreciated.
Thanks
Old Jun 1, 2009 | 12:48 PM
Thank you VERY much. I will have our engineers look at this right away!
Eric
