4" Intake vs. 3" Intake Testing
Has AMS tested the power difference between running a 4" intake vs. a 3" intake on a 35R turbo or larger setup? On my setup I'll still be utilizing the stock MAF sensor, but I'm wondering if there is more power to be had by using a 4" intake pipe w/ a reducer at the sensor. Any insight is appreciated
if you are still necking the inlet back to a 3" pipe for sensor, any gains will be negligable. The only gains you would have would be slightly decrease pipe flow losses from using a larger 4" pipe for a short section.
I was considering this if I went the 35R route but decided it would take quite a bit of tuning to get everything back in line. It wouldn't just be WOT operation either, all the lower load cruise maps would have to be dialed in with lots of datalogging and likely at a different percentage at idle, cruise, and full boost. The only reason I could see this helping significantly is if you want to drop down to a lower part of the load maps due to outflowing what the stock ECU can manage. You may be able to find someone that has dynoed a larger turbo with a 3" intake versus a 4" intake with no other changes.
Just use a 4" to 3" reducer at the turbo inlet and use a 3" intake pipe.
You pretty much need to run Speed Density. Removing the maf thats how you'll get a gain..... MAF makes a restriction, SO clearly a 4" intake on a 4" = 100% performance doing a 3" on a 4" is 75% AKA restriction.
LGshow19
41
Feb 22, 2011 02:29 PM
Mark@AMS
Automotosports - Illinois
49
Aug 31, 2010 07:42 AM
twinturbogreg
Aug 9, 2010 03:22 PM
Done
10
Oct 23, 2009 12:35 PM
