-   Automotosports - Illinois (https://www.evolutionm.net/forums/automotosports-illinois-71/)
-   -   Stay Tuned! FP Red on E-85 Dyno'd! (https://www.evolutionm.net/forums/automotosports-illinois/423664-stay-tuned-fp-red-e-85-dynod.html)
WannaRace May 28, 2009 10:35 AM
UPDATE: Page 2, #26
Added Dyno sheet
The time has finally come and my car is complete just the way I've always wanted it. It is a stock appearing 03 Evo with the following mods:
HKS Racing Intake
Buschur UICP
Buschur Deluxe FMIC
AMS LICP
Forge DV
Buschur DP w/ QTP cutout
Hallman Pro RX
HKS 272/272
Headstuds
Buschur Double Pump
FIC 1050cc injectors
Ported/Coated Stock Manifold, 10.5 Hotside, 02 Housing
FP Red w/ HP WGA
Otherwise stock block, head, transmission, etc. etc.
Soon to be tuned by Chris Black @ AMS on E-85
I will have dyno sheets up this weekend if everything works out and I'm not too busy playing around with the car :D
Evo a Mula May 28, 2009 11:27 AM
what do you think the car will make???
modetm May 28, 2009 11:36 AM
looking forward to seeing the numbers....
TxEvo8 May 28, 2009 12:06 PM
500hp/470tq is my guess.
CAD EVO May 28, 2009 12:33 PM
500 whp for sure
Its basically a mini 35r that will be on high boost
toylex May 28, 2009 12:39 PM
YEA i won2 see numbers....:D
WannaRace May 28, 2009 01:12 PM
I thought I saw a similar setup on AMS' dyno make around 450ish whp.. Don't quote me on that, but I thought I saw that somewhere
*Evil Evo* May 28, 2009 01:15 PM
ive seen atleast 2 other evos with similar mods and an fpred hit 500whp and 500wtq on E85.. good luck, chris is a badass... i love my E85 tune
Creamo3 May 28, 2009 01:48 PM
My guess is 450/450, your injectors might be a limiting factor in how far you're able to push it.
EricJ@AMS May 28, 2009 01:52 PM
I agree with Creamo3. 500whp is definitely out of the question.
WannaRace May 28, 2009 01:59 PM
Thats what I'm expecting, but Eric, is your reasoning because of the injector size as well?
evoWWrs May 28, 2009 02:24 PM
the FP red is good but it doesnt work magic!!! you dont have a huge amount of mods and most arent huge power mods!! 500 on a red would take a built block, better cams...
i believe you will be alright with your injectors with a dual FP... you will have some good numbers but my honest guess would be 420!!
ninekrevs May 28, 2009 02:25 PM
how much boost are you going to run? 500whp is possible if you go past 30psi. although you should of went with 1200cc injectors so you won't run out of fuel.
yahu May 28, 2009 02:46 PM
I'm very interested in this thread. I have similar supporting mods and have been debating which turbo to upgrade to. The FPRed is a front runner, but I don't have e85 readily available but am running 100% meth. Good luck this weekend, OP!
evoWWrs May 28, 2009 02:48 PM
e85 will get you to be able to run around 28 safely...
e85 and pump/meth is practically the same
