Boost Solutions - Georgia [Visit Site]
My car runs great!!!!!!!!!!!!!!!!!!!!
Old Jun 14, 2004 | 08:31 AM
mdzuricky77's Avatar
Talking My car runs great!!!!!!!!!!!!!!!!!!!!
Finally after eight months of me breaking my car off an on it runs great We finished up on Saturday/Sunday at 2:00am. I took it for a test run by myself and for the first time in my life, I scared myself. I know there are many fast cars out here that are a million times faster than mine, but my car is running quick for a stock turbo. Honestly, I don't understand. I lied, I know why. It's because of the mad skills of GEORGE and DOUG at BOOST SOLUTIONS. They do know how to tune. I would post my A/F graph, but it's easier to do this:
__________________________________________________ ______________
That is exactly what it looks like. 11.3 at wot flat. It doesn't so much as dip up or down at all. That is called PERFECT tuning. I truelly can't wait till I dyno. It's happening in July gentlemen so don't pressure me.
George,
Thankyou for all the parts and help. Without your help I would be trotting around on my feet.
Doug,
You know you're the man. You have more than proved yourself to me on your capabilities. Thankyou for all your help and teaching me as you went. I had a great time in Atlanta for those ten days.
Yankonia,
Since you've been on time you are therefore promoted to Private First Class on 14 JUN 04 with a date of rank of 14 JUN 04. You will be eligible for promotion to Specialist with a waiver in six months. Congratulations
THANKYOU VERY MUCH BOOST SOLUTIONS
VOTE FOR BUSH
Old Jun 14, 2004 | 03:10 PM
I forgot to mention what was don to my car this time:
1. New pistons and rods
2. Piston rings and rod bearings
3. Arp head stud bolts and rod bolts
4. Rehoned cylinder walls
5. Basically a complete engine rebuild
6. Tomei Cam gears
7. Cusco catch can
8. Defi heads up display - This is pimp
9. Retunning of course
I now have a brand new engine and then some. The engine runs so good I can't believe it. 0.8 bar on vaccum. I never saw that before. I also have my two-step launch set up for 7lbs off the line at 4500rpm. This works great
Once again, thankyou very much!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jun 14, 2004 | 03:11 PM
Sweet I'm not a Newbie anymore
Old Jun 14, 2004 | 04:37 PM
2Fast2Stupid's Avatar
Forget the AF ratio post a DYNO with the AF ratio and then I will tell you if you know how to use all 3. Boost, AF, AND TIMING.
Old Jun 14, 2004 | 06:20 PM
If you read my post entirely you will read that I am dynoing in July and I will personally email the chart to you first since you are so anxious. Better yet, you can watch me dyno so there is no question in your mind of Boost Solution capabilities. I'll keep you informed so please be patient.
Doug,
Post those datalogs please. Thanks!
Matt
Old Jun 15, 2004 | 06:31 AM
snoop's Avatar
Doug,
Matt
Don't forget to let us know when you DYNO.
Old Jun 15, 2004 | 08:11 AM
No problem
Old Jun 15, 2004 | 08:23 AM
evoate's Avatar
What cams? Engine mgmt? In other words, what was done to your car prior to these mods?
Old Jun 15, 2004 | 08:58 AM
evoego's Avatar
Registered User
good job, i am happy with Boost solutions as well. I will be back in town on Fri at the shop to see George,etc. Hope to see all the ATL evo peeps that know me.
Matt
Old Jun 15, 2004 | 01:59 PM
Noize's Avatar
EvoM Administrator
Where are you dynoing the car?
Also, a static A:F isn't a representation of tuning perfection, as there are definitely areas in the curve where you're leaving power on the table and that you could very safely go leaner. True good tuning is an art of manipulating air:fuel, boost, and timing to procure the best results without inducing any knock. While I think that a 11.3 is very safe, I'll bet there's room for improvement in spots. Drive around on that map for awhile and have George fine tune it when you put it on the dyno. If you like the car now, it will only be better when you get rid of that unilaterally conservative air:fuel line.
-Seth
Old Jun 15, 2004 | 02:18 PM
Why was all of this replaced? Sounds like a blow motor.
6. Tomei Cam gears
7. Cusco catch can
Old Jun 15, 2004 | 03:08 PM
Boost Solutions's Avatar
-Seth
Agreed, but is should a bit more miles on it, before we go and tune for 11.5-11.7
The receipe for power is air+spark+fuel. If one thing is missing, or off, the car will not perform to its full potential. Getting the air fuel ratio perfect, adding the spark ( timing) and raising the boost will be your ticket for the most power. The timing values should be as high as possible, without causing ANY knock at ANY temp levels. The boost should be as high as possible too without causing knock, or inefficianct of the turbo.
George
Old Jun 15, 2004 | 03:12 PM
9500rpm overrev while the stock clutch went out = broken piston skirt
so watch out now with your stock clutch
George
Old Jun 15, 2004 | 03:15 PM
6. Tomei Cam gears
7. Cusco catch can
We can retune it, but I do not know about any retunning
j/k
George
Old Jun 15, 2004 | 04:03 PM
Ryan,
You are such a genious Guess what though, it's not broken anymore mr. my clutch slips, my 4th gear grinds. You try to jump all over me every cahnce you get. If you knew me you would know that I say it like it is. Yes, I broke a piston skirt which resulted in an engine rebuild. Yes, it is now fixed and built even stronger than stock so yippy for me I guess I'll call you Captain obvious I really can't wait to dyno.
George,
When I said retunning, I meant touching up because we put the cam gears on. Easy cheetah! You know I love you ask Ryan
Later Dudes
